Author Topic: 89 Jetta N/A to TD little or no throttle  (Read 2476 times)
April 29, 2012, 06:21:53 pm
dieselherb1
  • 354
« on: April 29, 2012, 06:21:53 pm »
I swapped a 89 Jetta N/A into caddy, installed T3 turbo (engine had a altitude adj pump) Ihad the engine on the ground bolted to the trans and it was running fine without turbo. Now in the truck little or no engine speed above idle. Ran fuel from a bottle to pump no change. Thoughts?
Reply #1April 29, 2012, 07:00:16 pm
Re: 89 Jetta N/A to TD little or no throttle
« Reply #1 on: April 29, 2012, 07:00:16 pm »
How much did you mess with the pump?
It would seem that you have a throttle issue. Or a fueling issue, as it ran fine on the stand/floor.
Reply #2April 29, 2012, 07:11:18 pm
« Reply #2 on: April 29, 2012, 07:11:18 pm »
is there an air restriction in the turbo? Paper, mouse nest, etc?
how did you hook up the alt part of the pump?
Reply #3April 30, 2012, 09:05:07 pm
dieselherb1
  • 354
« Reply #3 on: April 30, 2012, 09:05:07 pm »
didn't mess with pump at all, turbo is spinng fine. Could the pin-shalf on the diaphragm cause a interference with the throttle?
