Author Topic: Advice: Check and change your air filter!  (Read 6003 times)
February 12, 2006, 02:37:01 pm
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
« on: February 12, 2006, 02:37:01 pm »
I just changed my air filter, and that... thing... is what I found.
I've been told that that thing is a GASSER air filter. It's about half the height of the new DIESEL filter I just put in, FWIW.
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #1February 12, 2006, 02:55:23 pm
SMOKEYDUB
  • 630
« Reply #1 on: February 12, 2006, 02:55:23 pm »
I was havingf nasty running problems last week i had no powe and black smoke everywere. I was noticing a power decrease a couple weeks before so finnally i got fetup and i check the airfilter and there was my problem.It got so clogged from dirt it sucked the air filter into the intake runners  :shock: so i took it out and i took it for a ride down the street and it was unbelieveable (for an N/A)
CHECK YOUR DAM FILTER NOW! (jokes)
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #2February 12, 2006, 04:23:34 pm
52 horses
« Reply #2 on: February 12, 2006, 04:23:34 pm »
I found a K&N for my na 1.6 lt diesel and it works great... Just clean it and re-spray the treatment and go again... Of cource it wasn't easy to find or cheap...
Reply #3February 12, 2006, 04:43:25 pm
bhtooefr
  • 305
« Reply #3 on: February 12, 2006, 04:43:25 pm »
NOOOOOOO!
Various tests have shown that there's no performance advantage to a K&N.
However, it has been proven that a K&N allows a higher flow... of dirt...
Reply #4February 12, 2006, 06:24:23 pm
Dr. Diesel
  • 1341
« Reply #4 on: February 12, 2006, 06:24:23 pm »
looks like you rolled over a sheep!
I've found no measurable power difference between paper and k&n. However, there was always a layer of grit on the inside of the turbo inlet pipe when using k&n. Paper, no.
k&n went straight into the garbage.
Reply #5February 12, 2006, 07:20:58 pm
HP
  • 225
« Reply #5 on: February 12, 2006, 07:20:58 pm »
So...
 K&N    - no
 PAPER - yes
Reply #6February 12, 2006, 11:25:23 pm
52 horses
« Reply #6 on: February 12, 2006, 11:25:23 pm »
Quote from: "Dr. Diesel"
lI've found no measurable power difference between paper and k&n. However, there was always a layer of grit on the inside of the turbo inlet pipe when using k&n. Paper, no.
So now you tell me.... How often did you clean the filter?? I was changing the  paper ones every 6 months and now with the K&N I'm going to be doing the clean every 3 months... The first cleaning will be March 1st I will let you know what I find.. My thinking was $70.00 once and be able to clean the filter where ever I was.. Instead of ordering the thick filters everytime for $12.00...
Reply #7February 13, 2006, 02:21:15 am
Master ACiD
  • 328
« Reply #7 on: February 13, 2006, 02:21:15 am »
you probably shouldnt clean the k&n very often. they seem to get more efficent at trapping dirt as they collect dirt from age.
Reply #8February 13, 2006, 03:52:32 am
52 horses
« Reply #8 on: February 13, 2006, 03:52:32 am »
Quote from: "Master ACiD"
Oh I was told that if my air filter is changed ever 6 months then to clean the k&n more often....
Thanks for the heads up as they get older....
Reply #9February 13, 2006, 07:49:17 pm
commuter boy
  • 277
« Reply #9 on: February 13, 2006, 07:49:17 pm »
My completely non-scientific test for K&N's unworthiness:
Coat intake tube with a bit of fine grease.  Run stock filter for month.  Swab finger down tube, notice how gritty it is.
Clean intake tube, re-coat with grease.  Run K&N for a month.  Swab finger down tube, prepare one's self to be shocked by how much more grit is getting through the filter.
Chuck K&N filter in garbage, replace stock paper air filter.
Reply #10February 14, 2006, 05:46:50 am
BlackTieTD
  • 1512
« Reply #10 on: February 14, 2006, 05:46:50 am »
if only i could get my hands on a rabbit TD airbox!
