Author Topic: TDI HEAD PORTING  (Read 42504 times)
April 24, 2012, 10:43:59 pm
tunedbandit
  • 47
TDI HEAD PORTING
« on: April 24, 2012, 10:43:59 pm »
Hi guys as it says
can porting a diesel cylinder help in general performance
anyone have any info on this if they have done it  :)
cheers Rick
Reply #1April 25, 2012, 11:21:50 am
Re: TDI HEAD PORTING
« Reply #1 on: April 25, 2012, 11:21:50 am »
Hi guys as it says
cheers Rick
there IS a RIGHT AND WRONG way to port a TDI head, so please wait till someone has a definitive answer!
im not the one with the answer tho :(
Reply #2April 25, 2012, 11:22:25 am
carrizog60
  • 978
« Reply #2 on: April 25, 2012, 11:22:25 am »
tdi or not an engine will always benefit from a well ported head
Portugal
Reply #3April 25, 2012, 11:43:13 am
« Reply #3 on: April 25, 2012, 11:43:13 am »
the TDI has swirl inducing runners tho, and there is a bump cast into the runner that NEEDS NOT BE REMOVED..
it will smoke like a train when its cold if you port the head, and dont know what your doing..
Reply #4April 25, 2012, 12:02:08 pm
carrizog60
  • 978
« Reply #4 on: April 25, 2012, 12:02:08 pm »
dont know abot that,but its like i said,a WELL ported head.
out here most of the +300hp tdi“s have ported heads,thats for sure.
Portugal
Reply #5April 25, 2012, 02:10:12 pm
tunedbandit
  • 47
« Reply #5 on: April 25, 2012, 02:10:12 pm »
thanks for all your advice guys,,,iam not planning on doing the porting myself it will go to a cylinder head specialist
i was just wondering if any you guys have ported heads  :)
Reply #6April 25, 2012, 04:50:53 pm
« Reply #6 on: April 25, 2012, 04:50:53 pm »
I don't have a TDI with a ported head, but my TD was and will be again soon. Big difference.
Reply #7May 01, 2012, 10:21:29 am
« Reply #7 on: May 01, 2012, 10:21:29 am »
take it to a guy that has DONE TDI HEADS BEFORE..
these are nothing like gasser heads, if you go too big on the port shape, and shave the swirl inducing bump out of the port, then it will be a cold blooded pig. it will smoke and run rough if the head is ported by someone who has no idea what they are doing, ive seen this exact thing happen before.. somebody RUINED a perfectly good TDI head because they didnt know what they were doing..
(and heads are NOT cheap)
Reply #8August 18, 2012, 02:00:35 pm
  • 3468
    • McScrubbins Body Wash
« Reply #8 on: August 18, 2012, 02:00:35 pm »
My aaz head had a "swirl bump" I attributed to Chinese casting. Removed it and the thing ran awesome. Heavily modified though...
Reply #9August 18, 2012, 10:51:21 pm
rallydiesel
  • 1880
« Reply #9 on: August 18, 2012, 10:51:21 pm »
Yeah, that would just be a casting flaw as you said. TDI's have a very obvious intake port shape that is crucial to proper combustion. IDI's are almost like gassers as far as porting goes.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #10August 19, 2012, 09:54:53 am
« Reply #10 on: August 19, 2012, 09:54:53 am »
I remember a while back Dave at pp was experimenting with tdi head porting he said if you took too much of the swirl part out they'd smoke white down low but run better up top I guess there is enough turbulence at higher rpms for combustion to happen correctly.  It's probably easy to figure out just by checking out what cummins guys do
Reply #11August 19, 2012, 04:56:43 pm
snakemaster
  • 405
« Reply #11 on: August 19, 2012, 04:56:43 pm »
what power were you thinking of , i think a std head good for round 220hp but some may no beter
Reply #12August 22, 2012, 12:07:38 am
gldgti
  • 488
    • http://scramjetsite.8m.com
« Reply #12 on: August 22, 2012, 12:07:38 am »
I did this myself on this 1Y (same as AAZ) head:
goes to
and
not much, just took the ridge off the inside of the port near the valve and opened up the manifold connections to the same size as the manifolds.
Made a noticable difference to driveability.
'91 Golf Cabrio 1.9TD
Reply #13August 25, 2012, 12:21:17 pm
  • 3468
« Reply #13 on: August 25, 2012, 12:21:17 pm »
I did very similar to my AAZ head. I went all the way to the valve stems and then removed any part of the stem that stuck out. Matched the ports to the gasket and then on the other size i opened the ports up all the way to the valve seats.
Resulted in incredible mileage and super torque under 0 boost. Flowed amazing. Looking forward to selling my head to someone who will use it well.
I was so happy with the results i will definitely be looking into doing some head work on the ALH I just got.
Reply #14August 28, 2012, 03:36:31 am
gldgti
  • 488
« Reply #14 on: August 28, 2012, 03:36:31 am »
Yup, I don't like to overstate it but it does make a huge difference to torque off boost.
