Author Topic: Who-sells-it: 0.5mm O.S. AAZ piston ring set  (Read 5580 times)
April 22, 2012, 08:19:04 am
CrazyAndy
  • 739
« on: April 22, 2012, 08:19:04 am »
Hey all
Had to bore mt AAZ 0.5mm over due to porosity in the bore surfaces.  I have a set of pistons for this oversize, but now I need to find some piston rings to go with them. Any leads to a good reputable brand would really be appreciated.
Thanks!
CrazyAndy
Reply #1April 22, 2012, 09:44:00 am
Re: Who-sells-it: 0.5mm O.S. AAZ piston ring set
« Reply #1 on: April 22, 2012, 09:44:00 am »
I do not know IF it works, but the TDI should be the exact bore size. Someone would have to chime in who has done it, but I would think you could use them in your aaz. As far as brand I was completely impressed with the Goetze brand in the diesel I did.
Reply #2April 22, 2012, 02:49:42 pm
CrazyAndy
  • 739
« Reply #2 on: April 22, 2012, 02:49:42 pm »
Mind if I ask what vendor or site you bought those rings from?  And I'm sure you're right about AAZ and TDI rings being compatible, I just can't find someone reputable who sells them, someone I can trust.  Being a diesel n00b makes my first-time purchases a little tentative.
Reply #3April 22, 2012, 02:51:19 pm
ilikevwdiesel
  • 1202
« Reply #3 on: April 22, 2012, 02:51:19 pm »
order a set from gowestyautoparts.com
get ones for a 98 Jetta TDI and you'll be all set.
My Bio
Reply #4April 22, 2012, 02:59:52 pm
CrazyAndy
  • 739
« Reply #4 on: April 22, 2012, 02:59:52 pm »
Thanks, but are the Grant's good quality?  The Goetze's only come in standard bore sizes, and ~$27 seems a little low-priced.
Reply #5April 22, 2012, 03:03:02 pm
ilikevwdiesel
  • 1202
My Bio
Reply #6April 22, 2012, 03:20:28 pm
CrazyAndy
  • 739
« Reply #6 on: April 22, 2012, 03:20:28 pm »
PERFEK!  ;D
/ordered.
Reply #7April 22, 2012, 03:22:45 pm
ilikevwdiesel
  • 1202
« Reply #7 on: April 22, 2012, 03:22:45 pm »
YOU CAN PROBABLY FIND THEM MUCH CHEAPER THAN THAT IF YOU LOOK AROUND!
My Bio
Reply #8April 22, 2012, 03:28:33 pm
ilikevwdiesel
  • 1202
« Reply #8 on: April 22, 2012, 03:28:33 pm »
My Bio
Reply #9April 22, 2012, 03:35:19 pm
CrazyAndy
  • 739
« Reply #9 on: April 22, 2012, 03:35:19 pm »
That's fine; NAPA didn't accept my plastic for some reason.  >:(
Tried IDParts already b4 thread; still STD size.
Reply #10April 22, 2012, 03:39:18 pm
ilikevwdiesel
  • 1202
« Reply #10 on: April 22, 2012, 03:39:18 pm »
I'd call the guy at ID tomorrow he must be able to get a .5mm oversize ring set.
My Bio
Reply #11April 22, 2012, 03:41:09 pm
CrazyAndy
  • 739
« Reply #11 on: April 22, 2012, 03:41:09 pm »
Yeah, I see where you are coming from; if he can get 0.5mm OS AHU pistons then he should be able to get just the rings.
Reply #12April 22, 2012, 04:45:30 pm
« Reply #12 on: April 22, 2012, 04:45:30 pm »
Call autohaus az. If they don't have it and you have a part # or car it came from they can usually get it. I wouldn't use Topline rings and I dont' know about the grant either. I have heard mixed reviews on the Grants.
Reply #13May 01, 2012, 07:41:37 pm
Re: Re: Who-sells-it: 0.5mm O.S. AAZ piston ring set
« Reply #13 on: May 01, 2012, 07:41:37 pm »
Call Summit Racing and order a set of Total Seal rings.
That's what I did. 5+ years later still ZERO blow-by.
Send from my mobile thingy. Never while driving though.
Reply #14May 01, 2012, 10:34:29 pm
  • 2932
« Reply #14 on: May 01, 2012, 10:34:29 pm »
I was going to suggest total seal too.
 I just needed to replace a broken oil ring  for the 80mm 1.7 pistons and they had them.
