Author Topic: Transmissions  (Read 1975 times)
April 20, 2012, 11:39:19 pm
Grey_Smoke
  • 83
    fling wing for the win.
Transmissions
« on: April 20, 2012, 11:39:19 pm »
Earlier this year l posted a transmission problem, and we came to the conclusion that my reverse idler gear was shot.  At the time I said that in the spring I would be wondering which of the three transmissions (that I have) I should be using.  Well, now is that time.
the three are
1. a "AGS13036
          4"  on a 1986/7/8 1.6 Turbo (that is the one that is broke, if necessary I will pull it apart and fix it) off a Jetta
2. a "ACH18105" on a 1.6 na it's also a 1986/7 but a golf
3. a "something," (that-I-don't-have-the-number-for-right-now) it is off of a 1986 1.6 na Jetta.
some my questions are
1. will the two Jetta's be the same?
and
2. which is the best one for a 1.6 turbo?
thanks in advance for any help.
« Last Edit: April 21, 2012, 11:46:17 am by Grey_Smoke »
2001 TDI
86 Jetta Coupe TD - Still going together
sold - the Gutless wonder - 97 AAZ
An Oldvolks Home
Reply #1April 21, 2012, 05:53:10 am
rs899
  • 647
Re: Transmitions
« Reply #1 on: April 21, 2012, 05:53:10 am »
ACH should be fine.  It works well on my 1.6NA
Reply #2April 21, 2012, 09:51:46 am
Re: Transmitions
« Reply #2 on: April 21, 2012, 09:51:46 am »
I would pick whatever has the tallest 5th gear if there's a difference. The turbo motors cruise so nicely on the interstate, mine will do 80 mph all day with no effort. I kind of worry that's a lot of RPMs for it but it will do it, I'm running an ACH trans. http://www.brokevw.com has the list of gear ratios.
