Author Topic: PCV or "donut" on valve cover  (Read 8693 times)
April 19, 2012, 09:04:32 am
rodpaslow
  • 670
« on: April 19, 2012, 09:04:32 am »
I broke this black round thing on the valve cover that goes to a provent unit - do I need a new round thing or pcv valve, or can I get away with just running a line from the valve cover to the provent 200?
My pcv or round black thing on the valve cover is open, there is no restriction or filter (I don't know if this is correct or someone took the guts out of it).  Is this correct for a 1.6 TD ('91 vintage)?
Reply #1April 19, 2012, 10:44:14 am
Re: PCV or "donut" on valve cover
« Reply #1 on: April 19, 2012, 10:44:14 am »
It's an oil separator - it's job is to reduce the amount of oil coming out of the breather, keeping it in the engine.  You can certainly run a line to the Provent without it, but you're going to end up with more oil in the Provent than you would otherwise.
You can get a new one, but they're kinda expensive for what they are.  Listed at about $40 through the first supplier I checked.  I'd probably do it if it were me though.
Reply #2April 19, 2012, 11:14:14 am
« Reply #2 on: April 19, 2012, 11:14:14 am »
if everyone else is like me, then they should have about 40 of these laying around..
i know i have a TON of them..
i imagine you could find a used one somewhere cheap or free..
Reply #3April 19, 2012, 11:34:46 am
rodpaslow
  • 670
« Reply #3 on: April 19, 2012, 11:34:46 am »
Thanks, I'll probably go to the pull-yourself auto wrecker and see if they have any MK2's and pull one off.
I know I have a spare, but as usual i can't find it...
Reply #4April 19, 2012, 03:09:03 pm
bbob203
  • 1789
« Reply #4 on: April 19, 2012, 03:09:03 pm »
anything one can do to reduce the amount of oil going into the intake thru the tube that comes out of that thing going to the intake tube?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #5April 19, 2012, 04:50:23 pm
« Reply #5 on: April 19, 2012, 04:50:23 pm »
catch can anyone?
Reply #6April 19, 2012, 06:04:00 pm
billybobf
  • 318
« Reply #6 on: April 19, 2012, 06:04:00 pm »
isnt that what that funky looking thing is, is a factory catch can?
Reply #7April 19, 2012, 06:08:50 pm
« Reply #7 on: April 19, 2012, 06:08:50 pm »
lmao, no..
its an oil vapor separator, thats about it..
it doesnt actually CATCH anything..
Reply #8April 20, 2012, 08:51:20 am
rodpaslow
  • 670
« Reply #8 on: April 20, 2012, 08:51:20 am »
I have an older NA (90 1.6) that I use mostly in the winter.  I checked it and it doesn't have one is has a mesh of some kind in the valve cover.  I suppose that why a NA doesn't need this?
Reply #9April 20, 2012, 08:55:32 am
« Reply #9 on: April 20, 2012, 08:55:32 am »
it was integrated into the valve cover on the OLD engines..
Reply #10April 20, 2012, 10:40:36 am
Trips_B
  • 57
« Reply #10 on: April 20, 2012, 10:40:36 am »
My 86 valve cover also has the mesh inside and came with the pcv to the intake.
I deleted the hose and inline heating element.  Then ran a hose from the pcv to a small breather filter and mounted the breather filter inside my intake cone filter.   ;D kinda ghetto but it works and its inside the fender anyways so it not visable
Reply #11April 20, 2012, 12:47:48 pm
bbob203
  • 1789
« Reply #11 on: April 20, 2012, 12:47:48 pm »
does having or deleting pcv have any advantage or disadvantage?
03 Jetta wagon TDi
Reply #12April 20, 2012, 02:59:51 pm
Trips_B
  • 57
« Reply #12 on: April 20, 2012, 02:59:51 pm »
Question:What is the PCV valve and what does it do?
Answer:The blowby vapors that end up in an engine's crankcase contain moisture as well as combustion byproducts and unburned fuel vapors. The crankcase is sealed to prevent the escape of these gases into the atmosphere, but the vapors must be removed to prevent oil contamination that leads to sludge formation. The positive crankcase ventilation (PCV) system siphons these vapors from the crankcase and routes them into the intake manifold so they can be reburned in the engine.
I think deleting it ie. "cover/plug the hole" is not a good idea.  However a lot of people will run breather filters and add catch cans for to remove the possibility of oil reaching their intake.
Catch cans like provent 200 seem to be the way to go.  Retaining crankcase ventilation, recurculating fumes and removing the chance of oil getting into your intake.
Running a breather filter on your VC works.  If you dont mind smelling fumes when your windows rolled down on a nice day and cleaning/replacing it on a somewhat regular basis
My .02 cents
Reply #13April 20, 2012, 05:53:23 pm
billybobf
  • 318
« Reply #13 on: April 20, 2012, 05:53:23 pm »
ok, but on a diesel, isnt a little oil in the intake just added fuel and upper cylinder lubricant?
Reply #14April 21, 2012, 11:23:43 pm
  • 2930
« Reply #14 on: April 21, 2012, 11:23:43 pm »
The MK3 PCV pucks have a 3rd port for a hose from the front of the block,.. like the AZZs.
