Author Topic: Front Motor Mount Bracket  (Read 2304 times)
April 14, 2012, 07:51:36 pm
shwak23
  • 417
    • Blackdog Junkyard
« on: April 14, 2012, 07:51:36 pm »
Why are these brackets different? How would the one with the threads at the top even work?
Reply #1April 14, 2012, 07:56:10 pm
Re: Front Motor Mount Bracket
« Reply #1 on: April 14, 2012, 07:56:10 pm »
its a older design.. upper starter bolt threads into it vs the coolent pipe...
Reply #2April 14, 2012, 08:06:14 pm
shwak23
  • 417
    • Blackdog Junkyard
« Reply #2 on: April 14, 2012, 08:06:14 pm »
Well yeah I get that... But what holds the bottom hole? The bottom just rattles about? Do you need to put a nut on the bottom starter bolt?
Reply #3April 15, 2012, 10:03:58 am
« Reply #3 on: April 15, 2012, 10:03:58 am »
yup..
theres actually 4! bracket types..
theres another one that has the nuts on the top and bottom of the bracket.
and then theres another one with NO nuts on it..
you use nuts to hold bolts in them..
Reply #4April 15, 2012, 03:20:42 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: Front Motor Mount Bracket
« Reply #4 on: April 15, 2012, 03:20:42 pm »
That is dumb. Oh well I guess I will clean and prime the one that doesn't force me to use nuts.
Sent from my DROID X2
