Author Topic: 2800rpm fuel cut?  (Read 5067 times)
Reply #15April 14, 2012, 02:01:18 pm
Gator79
  • 53
Re: 2800rpm fuel cut?
« Reply #15 on: April 14, 2012, 02:01:18 pm »
I am using the g60 intake so there is no over boost valve.
I adjusted the throttle lever one spline and now I get full peddle movement but it did not help the revving.
while doing this I noticed that who ever rebuilt the pump did not tighten the lock nut on what I think is the centrifugal governor shaft on the front of the pump and from the pictures I took of the pump before the rebuild it looks like it is also adjusted further in than before.
Reply #16April 14, 2012, 02:05:52 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #16 on: April 14, 2012, 02:05:52 pm »
Yes, that would be an excellent thing to set back to what it was  ;D
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #17May 14, 2012, 03:01:53 pm
Gator79
  • 53
« Reply #17 on: May 14, 2012, 03:01:53 pm »
Update: DO NOT use an "out" bolt for for your "in" bolt.  ;D
Reply #18May 15, 2012, 03:21:18 pm
« Reply #18 on: May 15, 2012, 03:21:18 pm »
Trying to run while breathing through a straw!!
