Author Topic: feeling of powerloss  (Read 5104 times)
Reply #15April 12, 2012, 06:40:42 am
smutts
  • 720
    ClackClackClackClackClack
Re: feeling of powerloss
« Reply #15 on: April 12, 2012, 06:40:42 am »
X2 on the boost dump valve on the intake. It blows when boost goes much over 10psi, and shuts again when well below 10psi. It did this on mine when it had been laid up for a few months, the wastegate on the turbo had siezed so it was on full boost all the time. Car would go like a scalded weasel then "poosh!" flat as a fart for a couple of seconds, then off it would go again. About a three or four second cycle. Fortunately it freed up after a couple of miles. Check the turbo isn't overboosting too.
Reply #16April 12, 2012, 08:41:00 am
guy plain
  • 121
« Reply #16 on: April 12, 2012, 08:41:00 am »
   sounds like what mine was doing...but....it stayed under powered for 10 min. orso.....wouldnt rev over 2800 rpm....so you think it may have stuck open fo that long and freed up? when i was driving i took the rpm up and down ....let it go to an idle...it didnt want to idle well at all...
