Author Topic: EGT gauge question.. Dumb question, don't hate  (Read 15015 times)
Reply #45May 01, 2012, 05:08:47 pm
92EcoDiesel Jetta
Re: EGT gauge question.. Dumb question, don't hate
« Reply #45 on: May 01, 2012, 05:08:47 pm »
Five bucks work for ya?  ;D PM me w/ your details & digits.
Sounds good! What gauge is the extension wire? I'll PM you my number in a little while..
Reply #46May 02, 2012, 04:21:17 am
Syncroincity
  • 727
« Reply #46 on: May 02, 2012, 04:21:17 am »
Dunno exactly, 24 or 26, or smaller... it's quite thin, single conductor. Individually insulated inside the SS sheathing. Doesn't really carry any load, just sensor signal.
Question for anyone with an EGT gauge; what is your reading at idle? I'm seeing about 215 deg. F , does that seem right, or low? Still have not had it out on the street yet to put a load on the motor, and revving it in neutral only kicks it up maybe 20 degrees. I have the Aircraft Spruce mini probe, and it does react immediately, I'm just concerned that having two connections and about 17 feet of wire might be biasing my reading down...
Thanks!
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #47May 02, 2012, 05:43:07 am
« Reply #47 on: May 02, 2012, 05:43:07 am »
When cold mine would idle around 200F, after completely warmed up I could get it to idle down to 250F and it would pretty much not get any cooler.
Reply #48May 02, 2012, 07:48:25 pm
billybobf
  • 318
« Reply #48 on: May 02, 2012, 07:48:25 pm »
holy cow, why 17 ft of cable? I would think that like three feet of cable would be more then enough on a standard car, have it come out of the exhaust straight through the firewall to the sensor, seems like 3-5 at the most
Reply #49May 03, 2012, 04:38:27 pm
Syncroincity
  • 727
« Reply #49 on: May 03, 2012, 04:38:27 pm »
Vanagon... engine in the back.  :-* All the way up to the front bumper, up behind the headlights to the grommets, and into the dash area.
JC McCavitt
'98 Jetta Wolfie
Reply #50May 03, 2012, 05:14:09 pm
billybobf
  • 318
« Reply #50 on: May 03, 2012, 05:14:09 pm »
gotcha, Im not not sure how the $30 ebay setup is going to work, seems to have a 10-20 second delay
Reply #51May 03, 2012, 06:22:41 pm
« Reply #51 on: May 03, 2012, 06:22:41 pm »
a 40 dollar micro 1000 is safe...from aircraft spruce.
Reply #52May 03, 2012, 06:25:18 pm
« Reply #52 on: May 03, 2012, 06:25:18 pm »
the ebay gauge, probe, and leads were $30...
wonder if the gauge would work with a micro1000?
Reply #53May 03, 2012, 06:28:11 pm
« Reply #53 on: May 03, 2012, 06:28:11 pm »
If it is K type leads then it should.
Reply #54May 03, 2012, 06:34:16 pm
billybobf
  • 318
« Reply #54 on: May 03, 2012, 06:34:16 pm »
yeah, and the gauge was only $10 plus three dollars shipping it took like 2+ weeks I think to ship
Reply #55May 03, 2012, 06:49:27 pm
« Reply #55 on: May 03, 2012, 06:49:27 pm »
IMHO what good is a gauge if it takes longer to show temps than what it takes to melt an engine? I had less than 90.00 shipped for the entire micro 1000, westach gauge, leads, and light kit. It only reacts as fast as you push and let off the pedal...
