Author Topic: New crankshaft bolt source/PN?  (Read 2395 times)
April 07, 2012, 09:31:59 am
sk8ordie
  • 20
« on: April 07, 2012, 09:31:59 am »
I searched and found nothing concrete.
I need a new crank bolt for a 1.6 NA, CR engine. I did read that many folks are using a later stretch type, 12 point bolt, however, there were no part #'s, and all the threads were old, when the dealer still had parts available.
is the bolt M12X45? or is it M14X45?
I'm running an ABF serp set, and I would like to replace the crank bolt. The bolt came loose turning the motor over by hand. The motor has since been re-built, and I don't want to re-use, the re-usable 6 point bolt that is currently in place.
Any part numbers, resources, etc would be appreciated. Sorry for the potentially redundant request.
I did find this link in a previous thread on this topic - but the site gives no description.
http://www.perfectimportparts.com/OEM/oemSearch.aspx?search=N90577101
Reply #1April 09, 2012, 05:20:47 pm
sk8ordie
  • 20
Re: New crankshaft bolt source/PN?
« Reply #1 on: April 09, 2012, 05:20:47 pm »
No one has replaced a crank bolt after a re-build? I don't want to re-use my old bolt with a serp set up.
Reply #2April 09, 2012, 05:47:17 pm
EcoTX
  • 113
« Reply #2 on: April 09, 2012, 05:47:17 pm »
I recently bought one of these for my 1.6TD after replacing the front main seal from the dealer for like 5 bucks.
Part number # N-905-771-01
It was a nice OEM quality 12 point, 12.9 grade bolt.
Reply #3April 09, 2012, 06:05:26 pm
bbob203
  • 1789
« Reply #3 on: April 09, 2012, 06:05:26 pm »
Germanautoparts.com they are 5buxxx
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4April 10, 2012, 02:55:31 pm
sk8ordie
  • 20
« Reply #4 on: April 10, 2012, 02:55:31 pm »
Awesome - thanks for the PN. I'll definitely look into it. I've spoken with 2 parts people and neither of them have been much help.
Unfortunately GAP does not sell the right bolt. They also suggest that you -do not- run an 8V gasser bolt (which they do have)
Reply #5April 10, 2012, 04:39:31 pm
« Reply #5 on: April 10, 2012, 04:39:31 pm »
The new stretch type bolt for IIRC the AHU and ALH is a perfect retro fit. I think the newest ones are bigger diameter, but I think the alh is still ok for the 1.6.
