Author Topic: Ruptured Fuel Shut Off Solenoid  (Read 2254 times)
April 06, 2012, 04:49:23 pm
Blocksmith
  • 261
    Wrench Lurker
« on: April 06, 2012, 04:49:23 pm »
Hey Guys, question here--is a ruptured fuel shut off solenoid indicative of a more serious problem inside the IP, or is it simply an isolated failure of the part?
I had replaced some seals on a pump that had been sitting for a while, put it back in and all, started fine, was idling when there was a loud pop and a small cloud of smoke. I thought something had snapped inside the pump. Tore it apart, (no damage that I can see) and was pleasantly surprised to find only the fuel solenoid had given up the ghost.
As you can see from the pics, it looks as though the plunger inside was less than happy, and perhaps seized, causing the plastic to fail?
I have ordered a new solenoid, but I just wanted to make sure that's the only thing wrong with the pump before I put it back in.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #1April 06, 2012, 05:42:12 pm
Re: Ruptured Fuel Shut Off Solenoid
« Reply #1 on: April 06, 2012, 05:42:12 pm »
if the pressure regulator is not regulating internal pressure, then i could see the shut off solenoid blowing apart..
Reply #2April 06, 2012, 10:05:30 pm
  • 2930
« Reply #2 on: April 06, 2012, 10:05:30 pm »
I've seen smoke escape from them but never fuel.
Reply #3April 07, 2012, 02:58:42 am
chopper03
  • 42
« Reply #3 on: April 07, 2012, 02:58:42 am »
Blocksmith, I have got a fuel shutoff that you can have. And a gauge set up to test internal pressure that you can borrow if you want to come
get it. Should be about 20 miles from you. 1148 Mehaffey rd. 37931
Reply #4April 07, 2012, 06:52:23 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #4 on: April 07, 2012, 06:52:23 pm »
RoR-- thanks for the pointer; looks like Chopper03 has offered to help me test your theory  ;)
fatmobile-- that's all it was; small puff of smoke, no fuel. Motor shut off immediately.
Chopper-- Thanks! I think I'll have to take you up on that offer  :)  I'll pm you here in a sec.
