Author Topic: Turbo vs NA Cylinder Heads  (Read 6475 times)
Reply #15April 10, 2012, 10:44:08 am
Re: Turbo vs NA Cylinder Heads
« Reply #15 on: April 10, 2012, 10:44:08 am »
Toby, grab an old TD exhaust (im sure you have 500 laying around) valve, and cut a notch in the valve stem. then throw it in a bucket of water.. tell us if it goes nuts once it touches the water..
i would totally cut a worn out TD valve, but i only have 4 exhaust valves, and they happen to be installed in a TD head right now..
Reply #16April 10, 2012, 07:44:42 pm
billybobf
  • 318
« Reply #16 on: April 10, 2012, 07:44:42 pm »
you know that in moist air that a sodium filled valve van do some serious damage right?
Reply #17April 10, 2012, 09:41:28 pm
Toby
  • 728
« Reply #17 on: April 10, 2012, 09:41:28 pm »
I have a set of TD exhaust valves on the bench and they look identical to the regular diesel stuff. So what would make me think they are sodium filled?
Reply #18April 10, 2012, 10:16:44 pm
« Reply #18 on: April 10, 2012, 10:16:44 pm »
I thought the sodium was only in the center of the stem.
Reply #19April 11, 2012, 09:02:41 am
« Reply #19 on: April 11, 2012, 09:02:41 am »
you guys know that water and sodium react right? sodium BURNS when you introduce water..
thats why i said to notch the stem of a valve.. that will expose the sodium, and allow the water to touch it, and react.
i wish someone would do it, and take a youtube video of it..
and i swear ive read somewhere in a bentley that it says to NOT GRIND THE VALVES on a TD, because of the valves being sodium filled?
Reply #20April 11, 2012, 10:34:07 am
« Reply #20 on: April 11, 2012, 10:34:07 am »
I know it does. I want to try this. But I think you would have to do more than "notch" the valve. I think you would have to saw the stem in half to get at the atomic sodium. I thought it was pretty well sealed in there. As far as grinding them, I don't know... maybe because they are hollow they are weaker? I don't think the sodium is that close to the surface though.
Reply #21April 11, 2012, 10:37:40 am
« Reply #21 on: April 11, 2012, 10:37:40 am »
when i say to notch a valve, i mean to take a grinder, and cut a notch half way thru the valve stem.. or cut the valve stem in HALF. that will surely expose the sodium.
Reply #22April 11, 2012, 02:26:51 pm
Trips_B
  • 57
« Reply #22 on: April 11, 2012, 02:26:51 pm »
I will take a look when I get home, I may have an extra valve but im pretty sure they were all tossed when I got rid of my extra head
Reply #23April 11, 2012, 02:51:17 pm
« Reply #23 on: April 11, 2012, 02:51:17 pm »
Other (usually turbo) engines had sodium filled valves, usually exhaust valves.
If you want to do a science experiment just make sure to wear eye protection and to put it on youtube.
Reply #24April 11, 2012, 06:18:56 pm
Dakotakid
  • 1240
« Reply #24 on: April 11, 2012, 06:18:56 pm »
This is why the replacement TRW valves for the hydros are so damned expensive.
Oem TD solid exhausts were sodium from the factory.
Every Bentley I have ever had has this warning in it.
Less argumentation. More reading.
Reply #25April 11, 2012, 07:36:39 pm
Trips_B
  • 57
« Reply #25 on: April 11, 2012, 07:36:39 pm »
sorry guys, I just went through and cleaned the garage and alas I have no extra exhaust valves to try this
