Author Topic: connecting rod damn-age  (Read 5076 times)
Reply #15April 06, 2012, 10:01:20 pm
  • 2930
Re: connecting rod damn-age
« Reply #15 on: April 06, 2012, 10:01:20 pm »
When you put the piston pin in the rod bushing there should be NO slop.
 They are normally installed and reamed to fit.
 The surface area of the bushing is much smaller than the rod bearings, all the same pressures are on the smaller surface area.
Reply #16April 06, 2012, 11:51:36 pm
billybobf
  • 318
« Reply #16 on: April 06, 2012, 11:51:36 pm »
just doesnt see the rotation that the big end takes ;)
Reply #17April 07, 2012, 03:36:27 pm
BigVWman
  • 332
« Reply #17 on: April 07, 2012, 03:36:27 pm »
Aren't the rods matched in weight group sets? Was the single the same weight group as the other 3? I'm not sure if its super critical merely mentioning it since i would suspect it could cause unusual engine vibration if diff size.
Tim
83 rabbit shell 92 cabby tdi conversion, 91 cabby aba conversion, 87 cabby,  87 gti,  01nb tdi new project,00 1.8t nb, 98 ranger,92 f150 flareside(its pink) 97 cabrio and a 00 cabrio!
Reply #18April 07, 2012, 03:46:55 pm
maxfax
  • 2126
« Reply #18 on: April 07, 2012, 03:46:55 pm »
Yes...  Considering these things vibrate anyhow chances are it wouldn't be too noticeable, but not good for anything either.. From past experience I've found that if you are replacing one rod it needs to be at least close to get it matched to the rest..  Don't want to have to take too much material off..
Reply #19April 07, 2012, 05:02:00 pm
wdkingery
  • 494
« Reply #19 on: April 07, 2012, 05:02:00 pm »
Yes Bentley would suggest replacing them in fours even. But he can eat it. I threw that rod on, didn't weigh it, it doesn't vibrate. It runs fine actually. If it runs long term I'm a hero
Reply #20April 07, 2012, 05:29:51 pm
maxfax
  • 2126
« Reply #20 on: April 07, 2012, 05:29:51 pm »
I've mixed and matched in the past with no short term ill effects..  They lasted till something else blew apart..  ::)  I must say, the one engine I had balanced (rods were within IIRC 2 grams difference) was amazing smooth...
