Author Topic: FS: TD core block and head, NA core motor - N.C.  (Read 6309 times)
April 03, 2012, 10:36:50 pm
wolf_walker
  • 1205
« on: April 03, 2012, 10:36:50 pm »
Located in 27864
Have a 1.6TD head minus the pre-cups, I have them but they have cracks.
Came off a running motor but had well worn valve guides, been sitting on a shelf
for years, includes cam.  $50 plus shipping
1.6TD block and internals, from same running motor, had low oil pressure at hot idle, assuming intermediate shaft wear.
This has been sitting outside awhile, the bores are not pitted and will clean up with an overbore just fine.  $50 picked up
1.6D Hyd NA block with internals from 85 or 86 Jetta, trans still attached.  Never tried to run this,
assume it's a core, timing belt is off but did not break.  $50 picked up
1.6D mech NA block with internals, been sitting on floor inside for years.  Was a good
running high mile 1.6, cyl's showed some vertical scuffing, nothing crazy, has some surface rust on cyls and is dusty and cruddy.
$50 picked up
Need this stuff gone or it's gonna go for scrap weight in a junk car.
« Last Edit: April 22, 2012, 12:20:55 pm by wolf_walker »
Mentat Text Two
Reply #1April 04, 2012, 04:26:14 am
Re: FS: TD core block and head, NA core motor - N.C.
« Reply #1 on: April 04, 2012, 04:26:14 am »
the 1.6 TD and NA heads...are they mech or hydro? If mech I maybe interested in both. Let me know.
Reply #2April 04, 2012, 04:52:53 am
wolf_walker
  • 1205
« Reply #2 on: April 04, 2012, 04:52:53 am »
Mech heads unless I'm loosing it.  :)
Mentat Text Two
Reply #3April 04, 2012, 05:20:47 am
« Reply #3 on: April 04, 2012, 05:20:47 am »
would you do a combo price plus shipping? Let me know I will probably send the coin tonight if needed for you to ship. zip is 44611 if you need it
Reply #4April 04, 2012, 07:45:20 am
wolf_walker
  • 1205
« Reply #4 on: April 04, 2012, 07:45:20 am »
$80 for the pair plus the ride, sure.  If you can use a 3rd I can pull it off that other NA motor and do $110 for three.
Let me know
Mentat Text Two
Reply #5April 04, 2012, 03:17:55 pm
« Reply #5 on: April 04, 2012, 03:17:55 pm »
I will pm you with my phone #
Reply #6April 04, 2012, 07:24:16 pm
camboscams
  • 324
« Reply #6 on: April 04, 2012, 07:24:16 pm »
I'd be interested in the TD block I assume it has piston oilers , is there any way you would be interested in meeting me any distance in between? I'm in 24401
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #7April 04, 2012, 07:26:55 pm
« Reply #7 on: April 04, 2012, 07:26:55 pm »
Pm'ed on all 3
Reply #8April 05, 2012, 10:37:59 am
Blocksmith
  • 261
    Wrench Lurker
« Reply #8 on: April 05, 2012, 10:37:59 am »
Which part of NC are you in? If you're in the western half of the state, I may be able to come pick up both the na blocks.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
Reply #9April 07, 2012, 12:13:17 pm
k5ryannc
  • 18
« Reply #9 on: April 07, 2012, 12:13:17 pm »
pm'd you about the td short block
81 caddy 1.8 fi 5sp 34-36mpg and resonably fast (dd)
86 jetta gl 1.6 idi td fixing a scam project (i got had)
88 tube sami with 1.6 idi td, toy trans +tbox+upsidedown, dana 300, 3/4ton axles 37's (work in progress)
Reply #10April 09, 2012, 04:24:25 pm
wolf_walker
  • 1205
« Reply #10 on: April 09, 2012, 04:24:25 pm »
Eastern-ish, 27803 about an hour east of raleigh but it's possible I could make it to Raleigh sometime.
I think I've responded to everyone, the better NA head is in theory spoken for locally but not paid yet, an NA and TD head are
waiting a shipping quote and in theory sold after that.
Leaving two NA blocks and a TD block that all have guts in and assume need rebuild.
I haven't seen any money yet  ;D
Mentat Text Two
Reply #11April 09, 2012, 05:47:19 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #11 on: April 09, 2012, 05:47:19 pm »
I guess I'll get in line for the heads as well if the sales fall through  ;D
Though, I kinda would like to buy it ALL if I were to make the trip out there, unless you could meet me in between somewhere.
I suppose it would be frowned upon if I were to show up at your door with money and buy the heads out from under the buyers already lined up....  ::)
Reply #12April 09, 2012, 05:49:33 pm
wolf_walker
  • 1205
« Reply #12 on: April 09, 2012, 05:49:33 pm »
Yeah, I'm trying to be fair and give everyone a chance to jump here.  I'll deff let you know what the deal is in the next few days at worst.
I suspect I'm going to end up with the three short blocks available.
Mentat Text Two
Reply #13April 10, 2012, 10:16:33 pm
wolf_walker
  • 1205
« Reply #13 on: April 10, 2012, 10:16:33 pm »
OK, all three heads sold, I have two NA short blocks and a turbo short block left.
Make me an offer on all three and come pick them up.
Mentat Text Two
Reply #14April 11, 2012, 04:35:07 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #14 on: April 11, 2012, 04:35:07 pm »
Hmmmm, that gets to be kinda difficult, eight hours one way for just the short blocks.... The only ride I've got that's reliable enough  ::) to trust with those distances only gets 20mpg  >:( . Any chance you'd be willing to meet somewhere in the middle?
