Author Topic: I know proethe/hansdieselparts.com is junk...  (Read 6606 times)
March 29, 2012, 01:58:08 am
bbob203
  • 1789
« on: March 29, 2012, 01:58:08 am »
but is his timing TOOL kit at least worth it?
« Last Edit: March 29, 2012, 06:28:04 am by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1March 29, 2012, 04:46:19 am
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
Re: I know proethe/hansdieselparts.com is junk...
« Reply #1 on: March 29, 2012, 04:46:19 am »
That would be THE LAST thing I would EVER consider buying from him...IDI nural pistons maybe but not a t-belt kit....heard horror stories!
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #2March 29, 2012, 05:59:12 am
« Reply #2 on: March 29, 2012, 05:59:12 am »
I cannot even believe you asked this.
Reply #3March 29, 2012, 06:23:14 am
bbob203
  • 1789
« Reply #3 on: March 29, 2012, 06:23:14 am »
sorry i meant timing tools  :-[
03 Jetta wagon TDi
Reply #4March 29, 2012, 08:42:43 am
« Reply #4 on: March 29, 2012, 08:42:43 am »
i would buy his timing tools if it was my last resort..
Reply #5March 29, 2012, 08:48:19 am
bbob203
  • 1789
« Reply #5 on: March 29, 2012, 08:48:19 am »
well I've done some searching around. this guy seems like a real P.O.S. so ill pay more from someone else probably parts place inc. Or does anyone have a suggestion on somewhere to get some timing tools. gonna be swapping my ip soon.
03 Jetta wagon TDi
Reply #6March 29, 2012, 09:08:59 am
« Reply #6 on: March 29, 2012, 09:08:59 am »
ebay, they sell used, and sometimes NEW snap-on tools for WAY CHEAP.. its usually only the dial indicator tho, but thats the hardest piece of the puzzle. if your creative at all, you can improvise all the other pieces of the tool set once you have the dial indicator..
Reply #7March 29, 2012, 09:49:19 am
Luckypabst
  • 502
« Reply #7 on: March 29, 2012, 09:49:19 am »
His timing tools are fine for occasional use. Finish is poor but they get the job done. Not sure if he has addressed it but the IP lock pin was a couple mm too short to work without grinding off some of the knurling, ultimately I picked up a nicer pin from another supplier.
Chris
'82 TD Westy
'81 NA Caddy
Reply #8March 29, 2012, 09:57:55 am
srgtlord
  • 797
« Reply #8 on: March 29, 2012, 09:57:55 am »
I was satisfied with the tools from parts place inc. Very nice machining especially on the cam-lock tool. In total it cost about $140 but worth every penny
Reply #9March 29, 2012, 04:59:20 pm
Baron VonZeppelin
« Reply #9 on: March 29, 2012, 04:59:20 pm »
The german guy on eBay, quit selling on eBay.
But his was a metric kit - and the gauge was worth the whole kit price.
On a budget :
You can get a pair of 8mm and 10mm compression-fit type gauge adapters for $25. Nice stuff.
A dial gauge from Harbor Freight about $10-20 (same one Prothe sells).
Not metric - but can convert measures yourself.
STANLEY 3" door hinge about $5 (camlock)
10-12mm deep well socket for pump lock
The Prothe kit is bottom of the barrel from start to finish -
but it can be used with the results you want in the end.
Reply #10March 29, 2012, 05:52:35 pm
pointynoggin
  • 93
« Reply #10 on: March 29, 2012, 05:52:35 pm »
I have proth timing tools and they work fine.  You just use the gauge to get you close anyway then tune by ear.
1991 Jetta 1.6TD, Giles Superpump,
Reply #11March 29, 2012, 11:48:48 pm
billybobf
  • 318
« Reply #11 on: March 29, 2012, 11:48:48 pm »
hey, just cuz its an active topic, I have a "rothenberger" or something cam belt, looks brand new came with my torn down 1.6d N/A and a tentioner new in a bag, Im probably going to run it for pre run testing just to prove the engine works, but I dont think I will RUN that belt/tensioner.
Reply #12March 30, 2012, 06:29:56 am
JessaBug
  • 112
« Reply #12 on: March 30, 2012, 06:29:56 am »
I wouldn't run it AT ALL.
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #13March 30, 2012, 07:12:35 am
« Reply #13 on: March 30, 2012, 07:12:35 am »
I have timed over 3 dozen engines with my prothe timing tools..
They are just fine.. the actual gauge part of the process does not have to be spot on precise within a thousandth of an inch.. many people time these by ear remember. If you line up all the marks it will run, probably pretty good too.. And this is without using the dial gauge at all yet.
so in summary, Prothes tools will do just fine. Plus you only need the gauge, save some money :).
Reply #14April 02, 2012, 05:39:26 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: I know proethe/hansdieselparts.com is junk...
« Reply #14 on: April 02, 2012, 05:39:26 pm »
It is amazing how well the stanley hinge works. The only thing I would like to own is a injection pump plug because my improvised ones are always slightly loose, and a timing gauge obv.
Sent from my DROID X2
