Author Topic: Reasons an injection pump can loose its prime overnight?  (Read 42468 times)
Reply #30April 21, 2012, 08:59:24 am
92EcoDiesel Jetta
Re: Reasons an injection pump can loose its prime overnight?
« Reply #30 on: April 21, 2012, 08:59:24 am »
Seems like you replaced a lot of parts unnecessarily.
The story of a mechanics life I say.  Live and learn to do better?
Check valve?  How about this one.
http://www.wvodesigns.com/products/wvo-conversion/hose-fittings/sst-check-valve-for-99-02-ford-7-3-psd.html
A wee bit spendy.
That check valve would work but you have to put some adapters in to fit the VW IDI hoses. Why not buy the VW check valves with the correct size barbs? There's one on the fuel sender and one on the water separator under the car on some model years. These check valves are also on most TDI's
Reply #31April 21, 2012, 11:18:02 am
Thezorn
  • 381
« Reply #31 on: April 21, 2012, 11:18:02 am »
A wee bit spendy.
No kidding
« Last Edit: April 21, 2012, 04:45:15 pm by Thezorn »
Compounded 93 AAZ
Reply #32April 21, 2012, 11:33:45 am
Toby
  • 728
« Reply #32 on: April 21, 2012, 11:33:45 am »
What cars have a water separator under the car? Or did you mean under the car near the water separator? Also which ones have the check valve in the tank? Having a couple of these in the tool box would be a great troubleshooting aid.
Reply #33April 21, 2012, 11:40:28 am
« Reply #33 on: April 21, 2012, 11:40:28 am »
Summit racing has a couple kinds  ~$20
Reply #34April 21, 2012, 12:00:49 pm
belchfire
  • 140
« Reply #34 on: April 21, 2012, 12:00:49 pm »
Mc Master-Carr(.com) is an industrial supplier that will sell to the average Joe and has about any kind of chech valve imaginable. I got a brass one w/ stainless ball mfg'd in 1952 off of E-bay for cheap.
The Owl of Minerva flies at dusk
'81 rabbit pick up  1.6 turbo diesel  SVO
Reply #35April 21, 2012, 07:00:07 pm
  • 4550
« Reply #35 on: April 21, 2012, 07:00:07 pm »
http://www.mcmaster.com/#standard-check-valves/=h7jmrw
More than enough to choose from.  Some already have hose barbs on them.  15 bucks
Reply #36April 21, 2012, 08:36:30 pm
92EcoDiesel Jetta
« Reply #36 on: April 21, 2012, 08:36:30 pm »
My Ecodiesel had a water separator under the car (since removed). There was also an inline  check valve coming off a barb of the separator going to the IP , and an inline check valve going to the sender for fuel return (not inside tank.).
Reply #37April 22, 2012, 05:12:34 am
srgtlord
  • 797
« Reply #37 on: April 22, 2012, 05:12:34 am »
I know my pump loses prime overnight, but with a simple  low pressure electric pump, problem solved  ;)
