Author Topic: Franken engine  (Read 11077 times)
Reply #15February 16, 2006, 09:17:38 am
dieseltim
  • 9
v10 tdi ?
« Reply #15 on: February 16, 2006, 09:17:38 am »
Ok, well that is why I was asking, I don't have one here to check specs of so until I can get info on specs of parts I am just looking. Like I said it is just for fun. So, if I come up with something that will work then great, if not then ok too. Any one have specs on the 2.0 tdi bore and stroke? Or maybe a set of pistons for a 2.0 tdi they don't need anymore.
Thanks, Tim
Reply #16February 16, 2006, 12:06:54 pm
16V-Sauger
Franken engine
« Reply #16 on: February 16, 2006, 12:06:54 pm »
they won't work, too. the have e large omega-style hole in the middle to squish the air/diesel mixture. the CR would be ~17:1
if you have a g60 block then it has 81mm bore. i'm waiting for my flat 81mm pistons, that would give me 1.8l
if you want more try to get a set of 9A pistons with the corresponding crankshaft. CR can be adjusted up to 22:1 and that stuff should handle the expectable power
Reply #17February 16, 2006, 05:56:39 pm
DVST8R
  • 535
Franken engine
« Reply #17 on: February 16, 2006, 05:56:39 pm »
I would have to say that "custom" is about your only option. Maybey oversize 1.9TD pistons??
The Brett of the board...
The Dark Side of Beauty.[/i]
Reply #18February 17, 2006, 02:49:47 am
16V-Sauger
Franken engine
« Reply #18 on: February 17, 2006, 02:49:47 am »
Quote from: "DVST8R"
is that related to me? if so, the pistons are from a gasser  :wink:
Reply #19February 17, 2006, 05:48:56 pm
DVST8R
  • 535
Franken engine
« Reply #19 on: February 17, 2006, 05:48:56 pm »
sorry no that was to Diesel Tim, as he was looking at using V10TDI piston's.
End Highjack  :wink:
Reply #20February 18, 2006, 08:12:03 am
SMOKEYDUB
  • 630
Franken engine
« Reply #20 on: February 18, 2006, 08:12:03 am »
i think the only place you could find v10 tdi pistons would be the dealer :cry:  but it would be interesting you would have to for sure make or get custom rods. Im sure it wouldnt be hard to find someone to custom make stuff for you. The only thing is when you start going full blown custom like you want to do it starts costing big dollars for something that might not be worth it. Just my two cents. I just think if you have a light car you can make it dam fast just using a 1.6 or a 1.9 worked over.
Jeff
12mm PUMP 'O' DEATH on a 1.6L
(courtesy of GILES)
2000 NISSAN XTERRA (5 SPD)
1984 RABBIT TD 2dr (SOLD)
1.8t AEB soon around 550 whp
Reply #21February 20, 2006, 08:54:36 am
BlackTieTD
  • 1512
Franken engine
« Reply #21 on: February 20, 2006, 08:54:36 am »
its a cool idea but as soon as you need custom pistons/rods like jeff said, it sort of kills the whole "cheap project for fun" aspect. i'd like to see you make it work... know any machinists??  :)
Reply #22February 23, 2006, 02:40:12 pm
dieseltim
  • 9
pistons / rods
« Reply #22 on: February 23, 2006, 02:40:12 pm »
Well, yes I can do some machine work but, if I can find some pistons that are 4th over (1mm over) for a TDI then maybe I can still do this without having to spend much time on the lathe or mill.
Dieseltim :)
