Author Topic: 1.6 and aaz valve diameters  (Read 7710 times)
March 23, 2012, 07:52:25 am
« on: March 23, 2012, 07:52:25 am »
1.6 is 34mm in 31mm ex
1.9 is 36mm in 31mm ex
Tdi is same as aaz but slightly different lengths
I robbed this from a post. Don't know if it is 100% accurate, but I wanted to be able to find this next time around. I think this is the main reason the aaz head is the upgrade to the 1.6...time will tell.
« Last Edit: March 23, 2012, 01:25:54 pm by theman53 »
Reply #1March 23, 2012, 09:38:29 am
Re: 1.6 and aaz valve diameters
« Reply #1 on: March 23, 2012, 09:38:29 am »
port shape is also much better on the AAZ.
Reply #2March 23, 2012, 10:58:47 am
rallydiesel
  • 1880
« Reply #2 on: March 23, 2012, 10:58:47 am »
And later AAZ and all tdi have 7mm stems as opposed to 8mm.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #3March 23, 2012, 01:27:00 pm
« Reply #3 on: March 23, 2012, 01:27:00 pm »
So I hear people say, but I really think the oval will flow better than the D. The D might have less turbulance or less tumble, but until my next project I won't know for sure.
Reply #4March 23, 2012, 01:28:12 pm
« Reply #4 on: March 23, 2012, 01:28:12 pm »
i would think the D port would flow better, because its bigger..
bigger ports usually flow better..
Reply #5March 23, 2012, 04:07:14 pm
« Reply #5 on: March 23, 2012, 04:07:14 pm »
Agreed somewhat. The my 1.6 head intake port measures 1-3/8 tall x 1-1/8 wide oval. My AAZ head intake port measures 1-7/16 tall x 1-1/16 wide. I really think the valve is the big difference in flow. The shape is probably to reduce tumble/turbulation, which should help performance. I want to do both a 1.6 and 1.9 head and see what actually does better at a HG change....horribly off the topic here, sorry. If I go further I will split the thread.
Reply #6September 10, 2012, 05:12:57 pm
erice1984
  • 263
« Reply #6 on: September 10, 2012, 05:12:57 pm »
I can vouch for the 1.9 and 1.6 Exhaust valves being the same diameter, I ordered them that way for my AAZ head.
The Intake valves are different, AAZ larger, 1.6 smaller.
1980 Rabbit 1.9TD
