Author Topic: providing oil to a turbo  (Read 5441 times)
Reply #15March 23, 2012, 02:10:53 pm
wdkingery
  • 494
Re: providing oil to a turbo
« Reply #15 on: March 23, 2012, 02:10:53 pm »
Found some have the spot already tapped, with a plug in them. But they are a booger to get off
Reply #16March 23, 2012, 02:17:53 pm
« Reply #16 on: March 23, 2012, 02:17:53 pm »
most are drilled/plugged..
but they are threaded in metric M10x1.0, witch is VERY CLOSE to 1/8" npt, but not quite the same.
Reply #17March 23, 2012, 07:24:04 pm
410
  • 581
« Reply #17 on: March 23, 2012, 07:24:04 pm »
Very true.  I'm guilty of cranking in a 1/8" pipe thread into one of these holes.  No leaks and never had a problem.  I don't recommend it though.
Reply #18March 23, 2012, 07:59:27 pm
wdkingery
  • 494
« Reply #18 on: March 23, 2012, 07:59:27 pm »
I'll be doing exactly that :-)
Reply #19March 24, 2012, 01:33:30 pm
camboscams
  • 324
« Reply #19 on: March 24, 2012, 01:33:30 pm »
For whats its worth, i have been supplying my vnt and the turbo before that with oil from the cylinder head location. I also primed my engine prior to swapping on the vnt and had quite a bit of flow.
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
