Author Topic: Anyone use a MK1 Rabbit Diesel filter on a TDI?  (Read 18812 times)
Reply #30August 24, 2012, 05:38:48 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
Re: Anyone use a MK1 Rabbit Diesel filter on a TDI?
« Reply #30 on: August 24, 2012, 05:38:48 pm »
The r12s filter is perfect with the exception that is only flows 15gph the diameter is perfect for the mk3 fuel filter bracket and the 140r mount isn't too expensive. I just think I would be starving the pump at sustained WOT.
http://www.parker.com/portal/site/PARKER/menuitem.de7b26ee6a659c147cf26710237ad1ca/?vgnextoid=fcc9b5bbec622110VgnVCM10000032a71dacRCRD&vgnextfmt=default&vgnextdiv=&vgnextcatid=2552&vgnextcat=140R%20FUEL%20FILTER/WATER%20SEPARATOR&Wtky=FILTERS
« Last Edit: August 24, 2012, 06:05:41 pm by G60ING »
Reply #31September 06, 2012, 09:47:59 am
« Reply #31 on: September 06, 2012, 09:47:59 am »
ive been running that fuel filter for a year or more now.. havent even had to change fuel filters yet!!
it does NOT starve the engine of fuel, but i pressure feed my filters..
Reply #32October 11, 2012, 03:20:53 pm
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #32 on: October 11, 2012, 03:20:53 pm »
I decided how to make room for the cat R1-0750 filter, it will be mounted off my corrado's radiator. Pictures will follow in the coming weeks.
Reply #33June 29, 2013, 08:18:08 am
G60ING
  • 170
    Corrado TDI
    • My VW Projects
« Reply #33 on: June 29, 2013, 08:18:08 am »
I made the cat fit:
