Author Topic: Oil seals  (Read 5069 times)
March 17, 2012, 05:12:39 pm
ToddA1
  • 434
Oil seals
« on: March 17, 2012, 05:12:39 pm »
I'm planning on changing the timing belt on my 1Z, so I figured I may as well change/check the crank pulley while I'm there.  While I have that off, I may as change the oil seals on the front of the engine.
I notice that this engine calls for Teflon seals.  I probably have at least 8 standard oil seals from my many years of standard gas and IDI VWs.  What's the deal with the Teflon seal?  I've read that it can be temperamental to instal and if you don't get it right, it'll leak.
What's wrong with the old style, if anything at all?  I dont want to spend an additional $30, if I dont need to.
FWIW, I found a Vaico crank sprocket for less than $15 at bestpricecarparts.  I see the same part for $40 at worldimpex.  Best price doesn't have the stretch bolt, though.
-Todd
Reply #1March 17, 2012, 05:19:43 pm
GTiTDi
  • 153
    Schnell Snail TDI performance
    • My 91 GTI --> TDI swap thread
Re: Oil seals
« Reply #1 on: March 17, 2012, 05:19:43 pm »
I got a vaico sprocket and was horrified at the low quality. returned it immediately. C.R.A.P. IMO.
91 GTI/ AHU spec'd 1Z power, GT2052W w custom adapter (available through me, PM me for details),TDTUNING software, PP764 nozzles, Massive spearco FMIC, PD intake, Koni reds
97 B4VGLX AHU, RC3, 357's, PP'd head, Shine springs and Koni yellows
Reply #2March 17, 2012, 05:27:39 pm
ToddA1
  • 434
Re: Oil seals
« Reply #2 on: March 17, 2012, 05:27:39 pm »
Really?  I thought worldimpex only carried quality parts.  Other than going to the dealer, what's a safe replacement?  Meyle, Febi, etc have all sent production to China (not that it's always bad), so quality will always be questionable.
-Todd
Reply #3March 17, 2012, 07:23:07 pm
Re: Oil seals
« Reply #3 on: March 17, 2012, 07:23:07 pm »
i used teflon on my tdi-m build... after 2 screw ups on the intermediate shaft seal.. i used a normal one on it..
i highly suggest pulling the vac pump.. and using a drill to double check all seals once installed to make sure none leak..
Reply #4March 17, 2012, 09:11:12 pm
Baron VonZeppelin
Re: Oil seals
« Reply #4 on: March 17, 2012, 09:11:12 pm »
I used a National seal on Int. Shaft seal - regular grade. (AHU)
There is an o-ring (viton ? - Green) on backside of seal carrier - get it too.
I didn't have the luxury of getting the o-ring locally when sourcing the seal - and reused the existing.
Reply #5March 18, 2012, 07:49:52 am
GTiTDi
  • 153
Re: Oil seals
« Reply #5 on: March 18, 2012, 07:49:52 am »
-Todd
I thought my supplier (worldpac) only carried quality parts as well, But I have returned more than a couple "OEM" brand products because of inferior quality. Lemme double check the brand of sprocket I have now..
Reply #6March 18, 2012, 05:44:56 pm
ToddA1
  • 434
Re: Oil seals
« Reply #6 on: March 18, 2012, 05:44:56 pm »
I've decided that I'm just going to use the standard seals, unless there's actually areason tat the Teflon seals are superior.
Any word on that crank sprocket?
-Todd
Reply #7March 18, 2012, 07:38:50 pm
Re: Oil seals
« Reply #7 on: March 18, 2012, 07:38:50 pm »
no spring to fail on teflon seal... the crank/cam is easy due to taper shaft... but im shaft.. id only use normal seal...
im almost 8k into my life test of the teflon seals with no leaks still...
Reply #8March 19, 2012, 09:38:10 am
GTiTDi
  • 153
Re: Oil seals
« Reply #8 on: March 19, 2012, 09:38:10 am »
-Todd
The sprocket I have now is an MTC...not a brand I was familiar with but the quality seems to be a lot better than some of the others I have seen.
