Author Topic: AHU to AAZ cluster  (Read 3790 times)
March 16, 2012, 12:50:12 pm
wadem
  • 32
AHU to AAZ cluster
« on: March 16, 2012, 12:50:12 pm »
So I found an instrument cluster on ebay for a 99 tdi. Looks identical to the one in my 96 IDI. Will a AHU engine cluster maych up to a Canadian AAZ ?
Wade
1996 Jetta 1.9 AAZ, addicted to Diesels!!!
340K and counting!!!
Reply #1March 16, 2012, 12:58:40 pm
Re: AHU to AAZ cluster
« Reply #1 on: March 16, 2012, 12:58:40 pm »
Wade
nope, not even a little bit..
the tachs read from different sources..
the lights and other gauges will work, but the tach will freak out..
Reply #2March 16, 2012, 09:46:57 pm
Baron VonZeppelin
« Reply #2 on: March 16, 2012, 09:46:57 pm »
Pretty sure RoR is exactly right on that.
The AHU is a fully electronic TDI with ECU, etc...
If you make a listing in the For Sale / Wanted section - you'll get some better exposure and more than likely have some options pretty quickly from the Canadian members. They had AAZ option from 93-97.
good luck
Reply #3March 17, 2012, 03:44:54 am
« Reply #3 on: March 17, 2012, 03:44:54 am »
if you install a TDI tach in an IDI car, it will read about 4000 at idle, and then bounce all over the place when revved, IIRC..
