Author Topic: Fix 1.6 or find a 1.9?  (Read 3013 times)
March 14, 2012, 04:35:51 pm
dl_sledding
  • 48
« on: March 14, 2012, 04:35:51 pm »
So, my 1.6td has problems (IC shaft bearings froze, need new crank, pistons, bore job, etc). Been contemplating the rebuild, and thinking maybe it's worth looking at a 1.9td replacement, or maybe even a TDI... I like the idea of the mechanical pump, so the TDI is probably out, but the TDI is most likely more available than the TD.
What's the "popular wisdom" here? I want to have a reliable running car, mostly for in-town use, but also for making some 100 mile + trips. I liked the mileage I was getting with the 1.6td (over 40), but sometimes I'd like a little go-power too, especially with the jerk in the Grand Prix GTP around here just asking to be put in his place...
Of course, as usual, budget is "as cheap as possible", LOL, but I figure I'm going to be spending $1000+ rebuilding this 1.6. Would that $ be better spent on a 1.9 td instead? Are 1.9's fairly easy to find, and what's a fair price in good running condition (I'm in the US, but very close to Canada)?
Thanks for any input on this.
Reply #1March 14, 2012, 07:47:26 pm
Re: Fix 1.6 or find a 1.9?
« Reply #1 on: March 14, 2012, 07:47:26 pm »
I do not think the 1.9 AAZ's were ever sold in America, so it may be tough to find one.. However they do make some good power stock.
But! if you buy a used engine it COULD need a rebuild as well, and then you could be in the hole for more than you want.
1.6TD's have been known to make some good power too. They can easily produce that which the 1.9 makes.
Reply #2March 14, 2012, 07:53:09 pm
Patrick
  • 1034
« Reply #2 on: March 14, 2012, 07:53:09 pm »
There's getting to be a lot of AAZ's around up here, you could drive up and thrash one in over a weekend if you found the right seller.... I like min in a mk2. Better engine than the 1.6
Reply #3March 14, 2012, 07:54:18 pm
« Reply #3 on: March 14, 2012, 07:54:18 pm »
Oh for sure, it is in every way better. Probably the reason why Volkswagen replaced the 1.6 with it in the NA market ;) lol.
Reply #4March 15, 2012, 07:15:27 am
« Reply #4 on: March 15, 2012, 07:15:27 am »
i think i will stick to the 1.6 engines.. they actually keep all their rod caps, and main caps in place..  :o
Reply #5March 15, 2012, 02:21:09 pm
« Reply #5 on: March 15, 2012, 02:21:09 pm »
I cannot really say as I have ran a 1.6, but not a 1.9aaz. I liked everything about my 1.6 except the EGT and the precups. AAZ has precups too, and with my pump would probably have the EGT as well. I would probably go with what you have  to make life easier.
Reply #6March 22, 2012, 04:15:09 am
« Reply #6 on: March 22, 2012, 04:15:09 am »
If I had all the cash in the world I'd build an mTDI for Jezzie... :D
