Author Topic: Marine Tachometer on Ebay  (Read 6554 times)
March 07, 2012, 12:07:00 pm
JDiesel
  • 35
« on: March 07, 2012, 12:07:00 pm »
Hey Dieselers,
I'm looking at a marine tach on ebay for my 1.6 rabbit.
It says this:
This 12 volt, illuminated tach will work for 80-100/110-140/140-170/170-200 teeth diesel motors. It uses a 3 1/4" cutout and measures 3 3/4" across the face including bezel.
There is an adjuster knob on the back for those 'teeth' settings.  Will one of them work on the rabbit?
Reply #1March 07, 2012, 12:43:26 pm
Re: Marine Tachometer on Ebay
« Reply #1 on: March 07, 2012, 12:43:26 pm »
sounds like the tach in question is meant to read off a reluctor ring, and these diesels have no such thing..
Reply #2March 07, 2012, 03:45:39 pm
camboscams
  • 324
« Reply #2 on: March 07, 2012, 03:45:39 pm »
Ummm, Flywheel teeth? that's how industrial stuff does it. it could be as easy as drilling a hole in the bell housing. Hopefully his flywheel has at least 80 teeth.
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #3March 07, 2012, 03:52:05 pm
JDiesel
  • 35
« Reply #3 on: March 07, 2012, 03:52:05 pm »
Yep :) Flywheels good. Forged in Germany, just put a new clutch in.
What I am looking for is a marine diesel tachometer for that W terminal.  Is there a specific one that works good? Any recomondations?   <=$50.00
Reply #4March 07, 2012, 07:03:31 pm
« Reply #4 on: March 07, 2012, 07:03:31 pm »
The only problem with most marine diesels are that they are bigger 5 or 6 cylinders.. and they only spin 3.5-4k rpm.. So a tach from them wouldn't be too useful as we can spin our motors to 6k.
Reply #5March 07, 2012, 07:31:28 pm
  • 4553
« Reply #5 on: March 07, 2012, 07:31:28 pm »
Upshift man, don't you know what the 5th speed is for?  LOL.
Reply #6March 07, 2012, 07:32:41 pm
« Reply #6 on: March 07, 2012, 07:32:41 pm »
I do mostly in town! LoL when it was my 1.6NA i was mostly above 4000rpm too! lol 5th gear.. pfft!
Reply #7March 07, 2012, 09:08:07 pm
Baron VonZeppelin
« Reply #7 on: March 07, 2012, 09:08:07 pm »
JDiesel, that "might not" have been a diesel specific tacho.
But anyway - you should find plenty diesel marine/tractor tachs on eBay that operate from an alternator signal. I used to find them for $40-60 new on eBay.
Reply #8March 07, 2012, 11:15:36 pm
JDiesel
  • 35
« Reply #8 on: March 07, 2012, 11:15:36 pm »
Well I'm trying really hard not to be out $40 on ebay... do all diesel tachs work on an alternator signal?
What about something like this?
http://www.ebay.com/itm/60MM-Stepper-Motor-DIESEL-TACHOMETER-RPM-GAUGE-METER-/220704701680?pt=Motors_Car_Truck_Parts_Accessories&hash=item3363067cf0&vxp=mtr#ht_5914wt_939
Reply #9March 07, 2012, 11:36:28 pm
« Reply #9 on: March 07, 2012, 11:36:28 pm »
No, some use a hall-effect type sensor, like a crankshaft position sensor on a gas engine or an ABS wheel sensor, with a ring that has teeth, often those are usually somewhat specific to the engine they're used on. I think optical sensors are another possibility but I've never seen this.
And some really old stuff is all mechanical, like a speedometer cable that comes off the engine.
Oh, and there some tools out there that measure RPM by the engine vibrations.
Reply #10March 08, 2012, 12:08:42 am
Baron VonZeppelin
« Reply #10 on: March 08, 2012, 12:08:42 am »
http://www.ebay.com/sch/i.html?_nkw=diesel+tach*&_in_kw=1&_ex_kw=&_sacat=See-All-Categories&_okw=&_oexkw=&_adv=1&_udlo=&_udhi=&_ftrt=901&_ftrv=1&_sabdlo=&_sabdhi=&_samilow=&_samihi=&_sadis=200&_fpos=Zip+code&_fsct=&_fsradio2=%26LH_PrefLoc%3D1&_sargn=-1%26saslc%3D0&_salic=1&_saact=1&LH_SALE_CURRENCY=0&_fsradio=%26LH_SpecificSeller%3D1&_saslop=1&_sasl=&_sop=15&_dmd=1&_ipg=200
There are several interesting ones listed.
You'll need to contact sellers and ask about alternator/generator signal - if its not listed in the auction. If they don't know - you might can google the part number/name of product and get more info.
Use   diesel tach*     just like that with the wildcard asterisk for search term. Then lowest price+shipping.
Check them all out - all the way to the end. Because sometimes there will be some cheap ones at the end of page due to shipping cost not being listed.
For example - like this one that comes listed at bottom after a $15,000.00 item.
http://www.ebay.com/itm/Volvo-Penta-Marine-Tachometer-taken-off-MD2B-inboard-diesel-/130658576273?pt=Boat_Parts_Accessories_Gear&vxp=mtr&hash=item1e6bdba791
« Last Edit: March 08, 2012, 12:11:20 am by Baron VonZeppelin »
Reply #11March 08, 2012, 12:12:58 am
Baron VonZeppelin
« Reply #11 on: March 08, 2012, 12:12:58 am »
I had to fix that search link
Believe its working right, now.
Reply #12March 08, 2012, 07:12:40 am
« Reply #12 on: March 08, 2012, 07:12:40 am »
here ya go.. idk why this cant be rigged up for under 40 bucks.. i did it for free.
http://www.vwdiesel.net/forum/index.php?topic=30442.0
after you build this setup, you can drive any aftermarket GASSER tach with it.. dont need diesel specific one.
i have NOT figured out how to make it operate a stock VW tachometer yet tho..
« Last Edit: March 08, 2012, 07:17:13 am by R.O.R-2.0 »
Reply #13March 08, 2012, 07:59:04 pm
ToddA1
  • 434
« Reply #13 on: March 08, 2012, 07:59:04 pm »
Wasn't jimbote running a standard VW gas tach?  Maybe the Ford sensor he used put out a stronger signal?
-Todd
Reply #14March 09, 2012, 11:03:52 am
« Reply #14 on: March 09, 2012, 11:03:52 am »
-Todd
prolly used a DSL 1.. or some other type of setup.. cause im using a strong pickup, and it doesnt even make a stock tach budge..
