Author Topic: Where to buy B3 Passat wagon rear springs/dampers for Mk2 Jetta  (Read 4825 times)
March 05, 2012, 04:58:05 pm
mrdane
  • 7
I'm looking for a inexpensive way to raise the ride height of my rear-sagging 1991 Jetta.  Anyone out there know a good source for these parts (new or used) and perhaps MK3 Jetta springs/dampers for the front also?
Thanks,
Dane
Reply #1March 05, 2012, 05:28:42 pm
Re: Where to buy B3 Passat wagon rear springs/dampers for Mk2 Jetta
« Reply #1 on: March 05, 2012, 05:28:42 pm »
Thanks,
Dane
you wanna put mk3 FRONT springs in the REAR?!?!
Reply #2March 06, 2012, 05:03:06 am
« Reply #2 on: March 06, 2012, 05:03:06 am »
The shocks in the rear...You could replace them and use a small section of approx. 2" diameter exhaust pipe over the shock and under the perch. Or I flipped the perch and got about an inch more. Depends on what you want to do and how much up you need.
Reply #3March 09, 2012, 09:11:16 pm
bbob203
  • 1789
« Reply #3 on: March 09, 2012, 09:11:16 pm »
http://www.vwdieselparts.com/forum/viewtopic.php?f=8&t=10837&hilit=lift+kit
did this over 6months ago. i regularly carry 300+lbs in my truck along with people have had any problems yet.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #4March 10, 2012, 03:15:28 am
Patrick
  • 1034
« Reply #4 on: March 10, 2012, 03:15:28 am »
Been using passat rear springs in a mk  2 jetta for a lot of years. Bought the struts off a wrecked '93 passat 4 door (not wagon) that was already on a trailer headed for the wrecking yard. If I remember right, I wound up cutting about 1 1/2 coils off to get the ride hieght reasonable, still higher that stock though. works good, lots of load capacity.
Reply #5March 17, 2012, 12:37:52 am
bbob203
  • 1789
« Reply #5 on: March 17, 2012, 12:37:52 am »
looks like ill be stealing even more stuff off the 94 vr6 in my local pull a part. I guess it makes sense passats are much heavier compared to jettas. I wonder if the front springs would be worth picking up as well I wonder if it would raise up my front end equal to my rear?
« Last Edit: March 17, 2012, 02:06:46 am by bbob203 »
03 Jetta wagon TDi
Reply #6March 17, 2012, 06:18:53 am
bbob203
  • 1789
« Reply #6 on: March 17, 2012, 06:18:53 am »
http://www.forums.ncdubs.org/showthread.php?t=17817
german auto parts dot com. sells jetta rear springs with a stiffer spring rate.
03 Jetta wagon TDi
