Author Topic: So I have some new injector nozzles for my 1.6 na...  (Read 4472 times)
March 02, 2012, 11:00:51 am
bbob203
  • 1789
« on: March 02, 2012, 11:00:51 am »
now what?
i got the basic idea of replacing them but what are the tips and tricks.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1March 02, 2012, 11:23:42 am
steevz
  • 229
Re: So I have some new injector nozzles for my 1.6 na...
« Reply #1 on: March 02, 2012, 11:23:42 am »
Vince Waldon has a great write up on rebuilding the injectors using new nozzles.
http://vincewaldon.com/index.php?option=com_content&task=view&id=20&Itemid=28
Reply #2March 02, 2012, 03:46:20 pm
Mark(The Miser)UK
  • 1557
« Reply #2 on: March 02, 2012, 03:46:20 pm »
now what?
Main goals:
To achieve  best running:
Match break pressures.
 Aim for about 5 bar above where you want them, if going by the book. [Because they settle]
Aim to be better than the 5 bar variation  recommended by the book, say 2bar
Match leakoffs.
Older ones tend to leak less, but if your new ones are a poor tolerance and leak off a lot, be sure to match leakoff volumes, to give matched injected volumes. The only way to do this is to buy 6 or 8 of them.
Matching spray patterns.
Not so important on an IDI, but no drips wanted, or exhaust will smoke.
Set timing to the book, get warm, then adjust timing  by moving pump, advanced or retarded until engine runs smoothly at idle. Usually just slightly retarded from 'bag of marbles' sound builds. Check acceleration... This is 'tuning' Measure and record actual timing figure with a timing gauge.
« Last Edit: March 02, 2012, 04:59:08 pm by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #3March 02, 2012, 09:40:14 pm
bbob203
  • 1789
« Reply #3 on: March 02, 2012, 09:40:14 pm »
i guess ill have to come up with a pop tester. :-\
03 Jetta wagon TDi
Reply #4March 03, 2012, 01:37:18 pm
bbob203
  • 1789
« Reply #4 on: March 03, 2012, 01:37:18 pm »
so I picked up my injector nozzles today from my parts guy. I thought I got 4 nozzles 1 per box well ended up being two per box so I have 2 sets. I also ordered a set of glowplugs. I paid 100 for everything. the gp's are meyle brand made in slovenia nozzles were made in czech republic also meyle brand. thoughts?
03 Jetta wagon TDi
Reply #5March 03, 2012, 07:12:21 pm
bbob203
  • 1789
03 Jetta wagon TDi
Reply #6March 06, 2012, 05:36:22 pm
Mark(The Miser)UK
  • 1557
« Reply #6 on: March 06, 2012, 05:36:22 pm »
pop tester i found on ebay made in india it looks like. worth it or is it garbage?
http://www.ebay.com/itm/Diesel-Injector-Nozzle-Tester-Pop-Pressure-Tester-Dual-Scale-BAR-PSI-Gauge-/320774405310?pt=Motors_Automotive_Tools&vxp=mtr&hash=item4aafa4fcbe
It looks as good as anything,but hard to tell accuracy of gauge. Not really a problem as long as you can see well enough to match the injectors.
Some of us like to fit 8" gauges ;D  but personally, I'd aim for an older item, that was described as fully working if it were cheaper...
Mark-The-Miser-UK
Reply #7March 13, 2012, 09:38:36 am
bbob203
  • 1789
« Reply #7 on: March 13, 2012, 09:38:36 am »
could anyone comment on the quality of the stuff i bought.
03 Jetta wagon TDi
Reply #8March 13, 2012, 12:50:38 pm
Blocksmith
  • 261
    Wrench Lurker
« Reply #8 on: March 13, 2012, 12:50:38 pm »
It does seem to be a trend for "European" manufacturing to be switching to the south-eastern eauropean countries... While I've not personally run into anything Meyle made in those two countries as of yet, it is a respected brand, so your components should be good (I'd put 'em in my car, for what it's worth). And furthermore, for the price you paid, it sounds like you got a pretty good deal.
Green 83 Rabbit 4dr, 5 speed ACH trans swap, ported 1.6D mech lifter w/ vnt15, na pump w/ gov mod, gasser intake mani, 2.5" exhaust, bilstein sports and cut mk2 springs, ss brake lines, 14" vw bottlecaps
