General Information
General
How much "PLAY" should be in the throttle shaft of an inection pump?
Topic: How much "PLAY" should be in the throttle shaft of an inection pump? (Read 3265 times)
March 01, 2012, 05:49:08 pm
srgtlord
March 01, 2012, 05:49:08 pm »
Just as the post indicates, How much play is acceptable before the bushing needs to be replaced?
March 01, 2012, 05:59:17 pm
410
Re: How much "PLAY" should be in the throttle shaft of an inection pump?
March 01, 2012, 05:59:17 pm »
Is it leaking fuel? I normally change the bushing if it's leaking fuel and changing the o-ring doesn't fix the problem. A little play is acceptable. You can also check to make sure the nut holding the lever on is tight.
Toyota truck 4x4 with Mtdi, M-vnt gt1749va, 11mm pump, fmic, smog .216 nozzles. Sold!
March 01, 2012, 07:51:55 pm
March 01, 2012, 07:51:55 pm »
The pump did not leak from the throttle shaft when pulled. A new o-ring was installed on the throttle shaft, and it was a tight fit to get the throttle shaft back in to the lid of the pump.
General Information
General
