Author Topic: 93 passat td pedal cluster in an mk2 jetta  (Read 3877 times)
February 29, 2012, 08:17:28 am
bbob203
  • 1789
« on: February 29, 2012, 08:17:28 am »
will it bolt in? will the throttle cable work? reason being the vacuum diaphragm for the cruise on a passat is part of the cluster attached to the gas pedal inside the passenger compartment in turn reducing the likelyhood of failure of the vacuum diaphragm that is under the hood(from heat and what not)also because mine has a hole in it anyway so it needs replaced. also removing some of the clutter around the ip with the removal of the oe mk2 cruise diaphragm linkage and bracket.  make sense??
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1February 29, 2012, 10:03:12 am
Re: 93 passat td pedal cluster in an mk2 jetta
« Reply #1 on: February 29, 2012, 10:03:12 am »
id just add the vac ball to the throttle pedal.. but since i have used a mk2 clutch/brake set up in my b3... with b3 gas still in it.. yea it will fit/work..
Reply #2February 29, 2012, 10:21:16 am
bbob203
  • 1789
« Reply #2 on: February 29, 2012, 10:21:16 am »
good idea!! ;)
03 Jetta wagon TDi
Reply #3February 29, 2012, 10:59:57 am
bbob203
  • 1789
« Reply #3 on: February 29, 2012, 10:59:57 am »
does it have to be from a diesel or will a gas one work as well.
03 Jetta wagon TDi
Reply #4February 29, 2012, 01:33:26 pm
« Reply #4 on: February 29, 2012, 01:33:26 pm »
should be the same..
Reply #5February 29, 2012, 07:36:05 pm
bbob203
  • 1789
« Reply #5 on: February 29, 2012, 07:36:05 pm »
these manual pedal clusters aren't for hydraulic clutches are they?
03 Jetta wagon TDi
Reply #6March 01, 2012, 03:56:44 am
« Reply #6 on: March 01, 2012, 03:56:44 am »
as far as i know gas is hydro.. and the diesel is cable.. but all you need to do is add the passat throttle
Reply #7March 01, 2012, 07:21:08 am
« Reply #7 on: March 01, 2012, 07:21:08 am »
read as:
it will be MUCH easier to just swap out the passat gas pedal, rather than the whole pedal assembly..
