Author Topic: Thread Size??  (Read 2258 times)
February 24, 2012, 08:55:54 pm
ein bora
  • 377
Thread Size??
« on: February 24, 2012, 08:55:54 pm »
Does anyone know the correct thread size of the banjo oil return line fitting/bolt going into a 1.9 idi block??
Thanks.
If you can't take advice - then you can't be helped!
Reply #1February 25, 2012, 08:00:56 am
Mark(The Miser)UK
  • 1557
Re: Thread Size??
« Reply #1 on: February 25, 2012, 08:00:56 am »
Thanks.
Oil returning from where? If I know that, I can look it up on the 'KATE'
EDIT Likely M10 or M12
« Last Edit: February 25, 2012, 08:08:17 am by Mark(The Miser)UK »
Mark-The-Miser-UK
Reply #2February 25, 2012, 11:07:20 am
Re: Thread Size??
« Reply #2 on: February 25, 2012, 11:07:20 am »
Thanks.
i believe its M12x1.5..
one way to check, try threading a lug bolt into the hole. if it threads in only part way, its m12x1.25..
if its just the wrong size, then its m10x1.5
Reply #3February 25, 2012, 12:16:01 pm
ein bora
  • 377
Re: Thread Size??
« Reply #3 on: February 25, 2012, 12:16:01 pm »
Ooop's sorry - from the turbo. It's a banjo fitting, threaded into the block.
Thanks.
