Author Topic: Building AAZ motor; meet Harley  (Read 116691 times)
Reply #240September 03, 2013, 07:58:24 pm
CrazyAndy
  • 739
Re: Building AAZ motor
« Reply #240 on: September 03, 2013, 07:58:24 pm »
AAZs don't need their pump body turned to set timing; the TB cog is set up for adjustment.  The pic doesn't show it, but the holes for the cog bolt are oval.
Not all AAZs are like this, but yours definitely is. That's a very interesting block heater.
Noted.
I got the block heater from Parts Place.  It uses a weird toggle-bolt-like holder, but it seals tight.  I figure it'll do fine.
Reply #241September 03, 2013, 08:43:23 pm
« Reply #241 on: September 03, 2013, 08:43:23 pm »
till the toggle breaks in the middle and it falls out the block when in a construction zone...
yes ive seen it...
Reply #242September 03, 2013, 09:33:32 pm
CrazyAndy
  • 739
« Reply #242 on: September 03, 2013, 09:33:32 pm »
yes ive seen it...
. . . fudge it, I'm taking it out.  Now I'm glad I bought an extra plug.
Reply #243September 04, 2013, 03:32:43 am
« Reply #243 on: September 04, 2013, 03:32:43 am »
just keep the spare in glove box... not too hard to install... hammer/socket... but i had one in my caddy let go... right after construction zone... id have been touchin my toes wishing for a kiss 5 min sooner...
had prestone in it... was installed w/grease on o-ring.. but looked like the o-ring had cristilized antifreeze that was odd corrosion effect and pushed it out the block... kinda like how a plastic neck deform on the head and breaks... but was under 2 year old... was still hanging in the hole.. so you could see how the t bolt bent/cracked... but drains coolent fast...
ill only use factory installed ones now...
Reply #244September 04, 2013, 04:40:05 am
« Reply #244 on: September 04, 2013, 04:40:05 am »
i had a similar one in my car with out issue. i probably only used had it in for a year or 2 before i sold the car tho.  i didn't have any issues with it, i installed it using silicone grease.
Reply #245September 04, 2013, 06:37:18 pm
CrazyAndy
  • 739
« Reply #245 on: September 04, 2013, 06:37:18 pm »
Fair enough.  I won't be using prestone, but I'll keep my eye on the seal.
Reply #246September 04, 2013, 07:09:52 pm
« Reply #246 on: September 04, 2013, 07:09:52 pm »
LOL.. but at that time it was only bested by blue vw stuff... pink no exist...
Reply #247September 06, 2013, 06:39:30 am
92EcoDiesel Jetta
« Reply #247 on: September 06, 2013, 06:39:30 am »
Spare freeze plug in the glove box? Install with hammer/ socket?  That I'd like to see with engine in the car.
Reply #248September 06, 2013, 09:55:14 am
« Reply #248 on: September 06, 2013, 09:55:14 am »
 ???  how most of us do... hell theman just did as one fell out...
Reply #249September 06, 2013, 02:37:17 pm
92EcoDiesel Jetta
« Reply #249 on: September 06, 2013, 02:37:17 pm »
There's no room to swing a hammer. What do you have to remove to hammer in a freeze plug when on side of the road?
Reply #250September 06, 2013, 02:55:18 pm
« Reply #250 on: September 06, 2013, 02:55:18 pm »
I did it in the grass, turbo, drain line, engine mount, and all in the way, so I don't know what you have to remove, but I do know what I didn't have to remove. I just had the freeze plug, hammer, and socket and tapped it in. MK2 jetta if that matters to you. It isn't as easy as walking and chewing gum but it is very possible to swing the hammer in there. I am not a small guy either.
« Last Edit: September 06, 2013, 02:57:03 pm by theman53 »
Reply #251September 07, 2013, 07:03:42 am
92EcoDiesel Jetta
« Reply #251 on: September 07, 2013, 07:03:42 am »
Did you do it from above or below?
Reply #252September 07, 2013, 07:41:21 am
« Reply #252 on: September 07, 2013, 07:41:21 am »
My preferred method:
Precisely because I have direct access.
Reply #253September 07, 2013, 08:21:52 am
bbob203
  • 1789
« Reply #253 on: September 07, 2013, 08:21:52 am »
What do you say about running on of these off the coolant line on the back of the head by the trasmission or pherhaps on the coolant hose on top by the alt? I would like to run on one in this position but it will make things a bit busy on a tdi with the factory oil cooler hose. Though now that I look at yours it is a td w/ oil cooler. I think warm startups are the key to reducing wear and maintaining longevity on these engines.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #254September 07, 2013, 08:58:31 am
« Reply #254 on: September 07, 2013, 08:58:31 am »
Sorry...I laid on my back in the grass, below the car and tapped it in. I did not take ANYTHING off...it is a turbo car with the sausage stuffer intake that I just did if you didn't read the thread, but if you did you would have to realize that no human could drop a freeze plug with those items attached from up top let alone hammer it in.
