Author Topic: Building AAZ motor; meet Harley  (Read 116881 times)
Reply #225August 15, 2013, 06:52:09 am
Re: Building AAZ motor
« Reply #225 on: August 15, 2013, 06:52:09 am »
if its only 1/8 or 3/16 off u can probably grind a little from the compressor housing and a little from the intake and everything will be happy go lucky, if not andrew number 1 has supplied you with a great solution.
Reply #226August 15, 2013, 07:40:16 am
« Reply #226 on: August 15, 2013, 07:40:16 am »
s bob needs to just have custom one like theman's made up.. overall probally best as performance gets a boost too.. just needs to be shorter as bunny hood closer then mk2 and well themans rubbing holes in the hood pad..
Reply #227August 15, 2013, 01:14:29 pm
CrazyAndy
  • 739
« Reply #227 on: August 15, 2013, 01:14:29 pm »
http://www.mandrel-bends.com/catalog/flanges-gaskets-36/header-flanges-194/volkswagen-209/volkswagen-8v-one-piece-header-flange-1-2-mild-steel-2358.html
This will be what I'm going to go with.  Chris, you make a very good argument for a new mani, but this is cheaper and less time overall, as Lucas counter-argued.  I know it lengthens the exhaust runners, but my car is small and my engine is big (compared to a 1.6); I think 1.9 liters and 25+ psi shouldn't have trouble getting 1800 lbs up to spooling revs. :)
Reply #228August 15, 2013, 01:34:35 pm
« Reply #228 on: August 15, 2013, 01:34:35 pm »
If you can get the necessary clearance with 3/8", then they also sell them 3/8" thick in both mild steel and stainless.  The 3/8" mild steel one is only $30.
Reply #229August 25, 2013, 10:20:35 am
CrazyAndy
  • 739
« Reply #229 on: August 25, 2013, 10:20:35 am »
Finally got some MK1 02A Transmission Mount brackets to replace the ones that were lost in the mail. They are admittedly not as high-quality appearing as the last set, but they are more functional, since the driver side trans mount bracket has the clutch cable bracket built in to it. Also, they were vastly less expensive than buying from domestic-produced competitors, even after adding shipping from Germany! They will get a coat of paint, a new rubber mount in the drivers mount bracket, and the trans will be ready to go in, once the 5th swap is completed.
Reply #230August 26, 2013, 07:39:38 pm
CrazyAndy
  • 739
« Reply #230 on: August 26, 2013, 07:39:38 pm »
Finally got my 0.681 ratio 5th gear installed into my 02A transmission. Had to wait until I could find a suitable gear puller, as the first attempt chipped teeth off the old gear. I really wasn't worried, as I figured this would happen anyway knowing my luck. Got the old gears off, new ones on, synchro and gear selector assemblies back on and adjusted, and side plate installed with new seal. Don't worry; the dent in the side cover does not interfere whatsoever with the gear selection mechanism. Couple that with the flywheel getting re-machined for the new clutch, and the transmission is ready for installation!
Reply #231September 02, 2013, 04:02:30 pm
CrazyAndy
  • 739
« Reply #231 on: September 02, 2013, 04:02:30 pm »
   The exhaust manifold flange/spacer finally came in the mail!  So I mounted it up, and found that the turbo now clears the intake manifold; hell yes!  Only now, the new exhaust studs that I thought would reach, don't.  D'oh.  Looks like I'll be needing a new set.  And just when the new turbo bolts come in, I find the old ones.  i'm on a roll for hardware this week.  I didn't let all that stop me from making progress; loose mounted the manifold and turbo so that I could get the turbo oil drain line fabricated.
   In other progress news, I started to get more things put on the engine.  Got the engine oil gauge sender, oil 'idiot light' sensor, one of the two coolant temperature sensors, and the block heater mounted.  Also got the fuel system mounted up with the rest of the hardware I received; injection pump mount and pump itself are now on the motor.  I had to clearance the Mk2 timing belt cover backing plate for the big AAZ pump hub, though.  Got the lines on hand-tight.  Just need to remember to bring a wrench from work tomorrow and they'll be on for good also.  Add hooking the injector return line up to the pump main return nipple, and you have 80% of the on-engine fuel system work done!
   It's all down to bolts, belts, hardware, gaskets, timing and tests now, folks!
Reply #232September 02, 2013, 04:50:27 pm
« Reply #232 on: September 02, 2013, 04:50:27 pm »
What is this engine for again??
Reply #233September 02, 2013, 05:08:55 pm
CrazyAndy
  • 739
« Reply #233 on: September 02, 2013, 05:08:55 pm »
My '81 Rabbit.  It's been waiting for this engine for 3 years.  Check the Driiive forum bar.
Reply #234September 02, 2013, 05:28:17 pm
« Reply #234 on: September 02, 2013, 05:28:17 pm »
Nice nice.
You're going to tighten down the lines prior to setting the pump timing??
Reply #235September 02, 2013, 07:35:43 pm
« Reply #235 on: September 02, 2013, 07:35:43 pm »
CrazyAndy, how are you dealing with the passenger side engine mount?
« Last Edit: September 02, 2013, 07:36:44 pm by 8v-of-fury »
Reply #236September 02, 2013, 09:10:40 pm
JASGTi
  • 61
« Reply #236 on: September 02, 2013, 09:10:40 pm »
I guess I missed it somewhere on the past 16 pages, but how are you going to setup the shifter for the 02A again?
I keep making notes for my own little project  8)
Reply #237September 02, 2013, 09:55:54 pm
Gizmoman
  • 1301
« Reply #237 on: September 02, 2013, 09:55:54 pm »
Looking real sweet Mr.
This would be a great time to add four wires and four fuses to the glow plugs ;D
Reply #238September 03, 2013, 06:55:17 pm
CrazyAndy
  • 739
« Reply #238 on: September 03, 2013, 06:55:17 pm »
Nice nice.
AAZs don't need their pump body turned to set timing; the TB cog is set up for adjustment.  The pic doesn't show it, but the holes for the cog bolt are oval.
MK1 gasser mount; already primed and loaded.
http://www.clausvonessen.de/pi69/pi38/pd648.html
Reply #239September 03, 2013, 07:46:40 pm
« Reply #239 on: September 03, 2013, 07:46:40 pm »
Not all AAZs are like this, but yours definitely is. That's a very interesting block heater.
