Author Topic: Building AAZ motor; meet Harley  (Read 116769 times)
Reply #165July 07, 2013, 09:36:39 pm
CrazyAndy
  • 739
Re: Building AAZ motor
« Reply #165 on: July 07, 2013, 09:36:39 pm »
Well, I tried to go out and torque down my main studs to 120 ft-lbs, but one of the middle ones decided that it wasn't having that.
Mains should definitely not be torqued to 120 ft-lbs.  The pic looks like a head stud, not main.
You are right; I mis-stated which studs I torqued.  Thank you for pointing that out.
Well I'm gonna go silent for a for the work week because I have to save up for new engine hardware, but I do have a question before I order.  Can you use the 1.6 main stud kit ARP 204-5402 on the AAZ without consequence?  I'm going to completely replace all Raceware hardware in my motor with ARP after the head stud let go;  I don't trust their stuff anymore.
Yes, the same headbolts are used so the same studs can be used. There is a TDI kit from ARP now, but I am still using the older ford cosworth kit that we have linked part #s to in the FAQ section.
Yup, forgot about that link.  Includes that very part number for the main studs; served me right for not remembering to RTFFAQ.
Reply #166July 10, 2013, 03:39:10 pm
CrazyAndy
  • 739
« Reply #166 on: July 10, 2013, 03:39:10 pm »
Five words to describe what came in the mail today:  Air. To. Water. Intercooler. Kit.
HELL YEAH!!!
Reply #167July 10, 2013, 07:22:26 pm
« Reply #167 on: July 10, 2013, 07:22:26 pm »
Reply #168July 10, 2013, 08:14:06 pm
« Reply #168 on: July 10, 2013, 08:14:06 pm »
someone is a pictarwhooore
Reply #169July 10, 2013, 09:07:12 pm
« Reply #169 on: July 10, 2013, 09:07:12 pm »
sat... that pic turns 1yo.. mikes pent house right there..
Reply #170July 11, 2013, 06:00:59 am
« Reply #170 on: July 11, 2013, 06:00:59 am »
HELL YEAH!!!
still on your grandma's nicely made bed for you.
Reply #171July 11, 2013, 06:17:48 am
« Reply #171 on: July 11, 2013, 06:17:48 am »
Why so much boost tubing?  A large reason for going air/water is to minimize boost tubing and lag.
Reply #172July 11, 2013, 07:59:31 am
bbob203
  • 1789
« Reply #172 on: July 11, 2013, 07:59:31 am »
Im guessing he is going to trim it down.
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #173July 12, 2013, 03:38:13 pm
« Reply #173 on: July 12, 2013, 03:38:13 pm »
I would think the most needed would be a 90° off the compressor outlet and then a 180° off the AWIC and a short run back into the intake.  That looks like 4 feet of extra aluminum and a couple extra couplers.
Reply #174July 12, 2013, 04:09:13 pm
stewardc
« Reply #174 on: July 12, 2013, 04:09:13 pm »
Mmmmm, nice. Whose kit is it? I think this belongs on my AAZ Torquemonster. 8)
Reply #175July 13, 2013, 11:17:34 am
« Reply #175 on: July 13, 2013, 11:17:34 am »
www.frozenboost.com !!!!!!!!!!!!!!!!!!!!!!! AMAZING CUSTOMER SERVICE AND PRICES!! :)
Reply #176July 14, 2013, 05:49:29 pm
« Reply #176 on: July 14, 2013, 05:49:29 pm »
yea libby.. problem is.. people like me take that tube, cut/weld.. if you have no "scraps/supply"... gotta start somewhere..
i myself.. id make mounts up off tranny for it so it can move with the engine.. mount it solid with no rubber couplers and a few v bands... this way no places to pop and make a boost leak..
Reply #177July 14, 2013, 05:51:16 pm
« Reply #177 on: July 14, 2013, 05:51:16 pm »
That is true Chris, but those couplers should hold up fine if they are from them.. friggan like 7 ply silicone.
Reply #178July 14, 2013, 06:14:39 pm
« Reply #178 on: July 14, 2013, 06:14:39 pm »
ha... get little oil between pipe and coupler buddy... they go pop real nice.. best part.. after the pop ther so much oil it does not stay together till you get it all dry..
Reply #179July 14, 2013, 09:40:17 pm
« Reply #179 on: July 14, 2013, 09:40:17 pm »
If the tube ends are beaded and the clamps are decent, they will hold to 30 psi.
