Author Topic: oil drainline  (Read 2518 times)
February 20, 2012, 12:02:59 pm
chrisg
  • 72
oil drainline
« on: February 20, 2012, 12:02:59 pm »
so i just got done putting a T3 on my car azz, its in a mk2, and everything is done and bolted up except the drain line, i have put the T3 flange on, but i can't for the life of me line it up and get the bolts in, its so tight back there and i can't see anything is there any trick to getting this line bolted up?
Reply #1February 20, 2012, 12:23:01 pm
Re: oil drainline
« Reply #1 on: February 20, 2012, 12:23:01 pm »
T3 never came on an AAZ.. what line are you trying to use? the mk1/2 line and the 1.6 oil pan, or the AAZ line that banjo bolts to the block?
Reply #2February 20, 2012, 12:42:21 pm
chrisg
  • 72
Re: oil drainline
« Reply #2 on: February 20, 2012, 12:42:21 pm »
i modified the line, so the old k03 line with the banjo fitting now has the T3 flange  on it. the problem is not the line, its getting the line in there and the bolts in. just wondering if there is a trick to doing this with everthing in the car.
Reply #3February 20, 2012, 12:49:50 pm
Re: oil drainline
« Reply #3 on: February 20, 2012, 12:49:50 pm »
you should be able to bolt the line loosely to the turbo, then loosely thread the banjo bolt in, then tighten everything up..
if you cant get it to work, then the line is too long..
Reply #4February 20, 2012, 12:51:05 pm
chrisg
  • 72
Re: oil drainline
« Reply #4 on: February 20, 2012, 12:51:05 pm »
so the best route is to bolt the flange up before the bango? i'll try that next
Reply #5February 20, 2012, 01:38:15 pm
Re: oil drainline
« Reply #5 on: February 20, 2012, 01:38:15 pm »
thats what i do. loosely bolt it to the turbo first.. then shove it in place and tighten it up..
