coolant hose part number 1.6td
Topic: coolant hose part number 1.6td (Read 3896 times)
February 19, 2012, 12:54:33 pm
b1rdjx88
February 19, 2012, 12:54:33 pm »
I need to replace one of the coolant hoses on my 87 jetta, but I haven't been able to find the part number for it. It's the short, straight hose that connects the steel return line to the waterpump down by the oil cooler. Does anyone have access to Etka, or know off-hand what the part number is?
It's hose # 7 in this diagram:
Last Edit: February 19, 2012, 12:58:45 pm by b1rdjx88
February 19, 2012, 01:08:33 pm
jb86
Re: coolant hose part number 1.6td
February 19, 2012, 01:08:33 pm »
I've bought that from German auto parts and from parts place inc
When I get home I'll look to see if there's a Vw part number on one
But you can call and get the hose from them
Jon
February 19, 2012, 01:13:01 pm
February 19, 2012, 01:13:01 pm »
068121063M
Meyle
Cooling/Coolant Hose; Water Pump to Pipe
1 per car.
http://www.autohausaz.com/index.html
Round 2
February 19, 2012, 01:51:03 pm
Baron VonZeppelin
February 19, 2012, 01:51:03 pm »
The AutohausAZ part number is also the VW part number.
fwiw
February 22, 2012, 10:09:16 am
JamesT
February 22, 2012, 10:09:16 am »
Vagcat.com gives you part numbers. You have to sign up, but it's an awesome resource.
93 Golf - AAZ with some fueling
78 Rabbit - 1.5 DIESEL (finally)
[(+)===o===(+)]
(++\==o==/++)
February 29, 2012, 04:24:45 pm
GEE-BEE
February 29, 2012, 04:24:45 pm »
SILICONE ON EBAY FROM MK1AUTOHAUS
I know cause I make all his ***.....
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
February 29, 2012, 08:49:29 pm
Baron VonZeppelin
February 29, 2012, 08:49:29 pm »
GB makes some NICE Stuff with Silicone.
Lifetime quality stuff
