S-PAutomotive.com
Author Topic: Injection Pump leaking  (Read 15738 times)
February 18, 2012, 09:52:08 pm
slavik19
  • 59
« on: February 18, 2012, 09:52:08 pm »
hey guys i have a mk1 style 1.6d injection pump.
it recently started leaking the engine sat for a while.
it prob never been rebuilt.
i cant afford to have it rebuilt.
i cant figure out where its leaking from.
drop of fuel every 2 secs.
and its getting worst.
what seals to check for? why is it leaking?
looks like its coming out the side where the fuel lines are connected.
i checked all the fuel lines and other bolts all tight.
can i fix this myself?
Reply #1February 18, 2012, 11:29:27 pm
  • 4391
Re: Injection Pump leaking
« Reply #1 on: February 18, 2012, 11:29:27 pm »
slavik19  to answer your question- can i fix this myself?  Yes, there is a kit that replaces all the internal o rings and gaskets and you need to get the front seal as well.  This site has a great pictorial on what it is you need to do when rebuilding the pump.  Read the pictorial and order up the parts from any of the many online places out there.  Fix is like 50 bucks total if I remember correctly.
DAS
Reply #2February 19, 2012, 12:05:58 am
slavik19
  • 59
« Reply #2 on: February 19, 2012, 12:05:58 am »
found the link
http://crustycrank.com/resealinjpump.htm#injpump
this is prob the seal thats bad in my pump
Reply #3February 19, 2012, 12:31:14 am
  • 4391
« Reply #3 on: February 19, 2012, 12:31:14 am »
Easy peasy fix.  Some folks have even done it on the car.  It is a matter of getting the pump to come apart enough to slide the o ring on the outside of the pump without actually taking the pump completely apart.  There are four bolts that hold the corners on and you loosen them all but don't let the pump come apart.
Then take a bolt out all the way. slip behind the o ring with a piece of hooked rod or a thin screwdriver and stretch it out enough to get the bolt back in.  Go around all corners until the bad o ring is on the outside of the pump and roll it back and off.
New O rings will be stiffer and some tape the outside of the pump with masking tape or duct tape to protect the new ring.  Install is in reverse.  One thing you do have to do is find a longer bolt that goes in the middle of the pump where the plug is.  That plug comes out and you install a gauge to measure the throw of the piston to time the engine.  But in this case you want to be able to put some pressure on the end of the piston to hold it in place otherwise when you release the pressure when you back off the pump head all the internals come apart.  Not a good thing.  Then you are forced to remove the pump from the car and really have a big rebuild to do.
Sliding the o ring off is doable by anyone with the proper precautions.  Search the thread I think someone had this discussion going just a bit ago.
Do it, that diesel really is hard to get rid of out of the concrete driveway.  And if blacktop it eats it away.
Reply #4February 19, 2012, 01:07:03 am
Baron VonZeppelin
« Reply #4 on: February 19, 2012, 01:07:03 am »
I've done 3 or 4 of those "on the car" without removing the Inj Pump.
You can buy just that O-Ring from a Bosch Certified diesel repair shop.
$2-3-4 iirc, and it will be green.
There is more to be known to do a fool-proof job on this than what is included within that tutorial you linked. But that is a good general basis to start with.
I walked Steevz through the finer points in one of his recent threads, in conjunction with the crustycrank tutorial. Shouldn't take too long to find it.
Either here in T-shooting section or IDI section.
Reply #5February 19, 2012, 09:27:16 am
slavik19
  • 59
« Reply #5 on: February 19, 2012, 09:27:16 am »
thanks for the help guys ill be calling the stealership tommarrow.
and re-reading this while i do it.
also while on the injection pump topic i noticed Governor mods and timming advances.
i understand that timming should be pretty simple. i know i have a timming tool somewhere around my garage. it came with the gasser. hope its the same stuff.
better mpg and acceleration
givernor mod seems really good.
what am i actually doing? cut the spring shorter?
is it hard to get to disassmble then assemble.
thanks again guys really helpfull
Reply #6February 19, 2012, 06:54:49 pm
Baron VonZeppelin
« Reply #6 on: February 19, 2012, 06:54:49 pm »
VW Dealer more than likely will not service that O-Ring.
If they "can/will" get it for you - probably 5X-10X the price.
Go to the yellow pages and find a diesel repair shop.
Be prepared they will tell you it cannot be done without failure - unless pump is removed and disassembled.
Don't argue or debate - just get the O-Ring - and thank them for the advice.
Pump Head O-Ring  # 2 460 210 012  (Bosch part #)
To do the timing precisely on our IDI's you have to have a dial indicator gauge and an adapter for it to screw into the Inj Pump. So that might not be the same as what the gasser came with. Unless it was a piezo timing light that reads pulses from the fuel injector lines. Gassers usually just use a conventional timing light that reads signals from spark plug wires.
You can adjust the timing by ear - moving pump towards the engine advances the timing - moving it towards the radiator retards the timing. Just don't go too much advanced - just to finest point without excess rattle.
Reply #7February 21, 2012, 10:14:33 am
JessaBug
  • 112
« Reply #7 on: February 21, 2012, 10:14:33 am »
If you've never timed a diesel before, I'd get a dial gauge. We know our TD pretty well and always use the gauge. Nice to get the numbers exact.
Mine - BMP 20thAE GTI
His - '01 Jetta TDI
Our project: '84 Jetta TD
Reply #8February 21, 2012, 11:32:14 am
smutts
  • 720
    ClackClackClackClackClack
« Reply #8 on: February 21, 2012, 11:32:14 am »
There is a big potential pratfall with this method, if the pump plunger comes too far with the head then some of the shims can fall out into the guts of the pump and destroy it, if you are unlucky. There are tricks to prevent this, so make sure whatever guide you use mentions this. If it doesn't, then they were lucky. ;D
Reply #9February 21, 2012, 05:05:26 pm
slavik19
  • 59
« Reply #9 on: February 21, 2012, 05:05:26 pm »
i messed everything up. i decided to take the nozzel things off the pump so i wouldent have to stretch the seal as much. the nozzel tips the metal fuel lines connect to. well it broke off. i try welding a bolt on. no luck. heat it up keeps cracking. i need a new pump. and so broke at the moment. need my financial aid money like now
Reply #10February 21, 2012, 05:37:17 pm
damac
  • 530
« Reply #10 on: February 21, 2012, 05:37:17 pm »
That sucks, are all your parts rusty?  Maybe somebody impacted them on instead of proper torque?
Looks like your cheapeast route might be to go on ebay and get a parts pump?  Then you could get a cheap reseal kit on ebay and break down and clean your pump, swap parts then get back on the road.
I did the high end seal once.  Then I got another leak and said screw it and pulled the pump and resealed everything.
If you have tools and a vice taking apart one of these pumps is no big deal.
1985 turbo diesel jetta
Reply #11February 21, 2012, 05:39:13 pm
« Reply #11 on: February 21, 2012, 05:39:13 pm »
why did you take the delivery valves out? or try taking them out?
the pump head is bigger than the area that those delivery valves take up..
you HAVE TO stretch the seal to get it on, no matter what.. the DIYs dont mention removing the delivery valves for a GOOD REASON.
and if you feel it necessary to remove them, use an impact gun to do so. they tend to come loose alot easier when you use some impact to loosen them, rather than sheer twisting torque.. delivery valves are thin and weak as you found out..
a new pump head/plunger will get you fixed right up..
i imagine you can score one for a few bucks from one of us ;D
« Last Edit: February 21, 2012, 05:41:10 pm by R.O.R-2.0 »
Reply #12February 21, 2012, 05:54:08 pm
slavik19
  • 59
« Reply #12 on: February 21, 2012, 05:54:08 pm »
yea i know you can call me a dumbass one more time. at the time is looked like a good idea. its unbelieve how tight it was. tried welding a bolt onto what ever of the nozzel was left no luck.  so im screwed right now. borrowing money. i have a 1.9tdi pump laying around is the pump head the same?
my pump worked well. just recently started leaking. im afraid if i take the head off a whole bunch of springs are going to jump out.
what do you guys think about these?
http://www.ebay.com/itm/VW-DIESEL-RABBIT-INJECTION-PUMP-/220956979552?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AVolkswagen&hash=item33720ff160&vxp=mtr
http://www.ebay.com/itm/150759171822?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
Reply #13February 21, 2012, 11:04:17 pm
« Reply #13 on: February 21, 2012, 11:04:17 pm »
PM SENT.
Reply #14February 21, 2012, 11:36:27 pm
  • 4391
« Reply #14 on: February 21, 2012, 11:36:27 pm »
Crap, Crap, Crap, and double crap.  I had a spare pump a bit back but now is on my spare IP.
Didn't think anyone would try to remove the check valves as it is not necessary, really not.
Live and learn,  bother is that it costs money to do that.
DAS
S-PAutomotive.com
