S-PAutomotive.com
Author Topic: Injection Pump leaking  (Read 15382 times)
Reply #15February 22, 2012, 12:06:32 am
slavik19
  • 59
Re: Injection Pump leaking
« Reply #15 on: February 22, 2012, 12:06:32 am »
guys you are awesome thanks for everything i need the car back on the road asap.
rebuilt seems very logical
but i need a pump faster then that.
what do you guys think of this one?
http://www.ebay.com/itm/VW-DIESEL-RABBIT-INJECTION-PUMP-/220956979552?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AVolkswagen&hash=item33720ff160&vxp=mtr
maybe later i can get a pump thats rebuilt and keep as spare.
Reply #16February 22, 2012, 03:41:32 am
Baron VonZeppelin
« Reply #16 on: February 22, 2012, 03:41:32 am »
From where you stand - nothing too much to lose.
Have read many times about the wonders of wax.
Mindfully and cautiously heat it up with heat gun or propane torch and rub a candles butt into it a few times.
Tink it with something good a few times-
then use an easy-out /or/ drive-in extraxtor tool to remove it.
Most times PB Blaster usually does the trick for me -
not had to go with wax yet. And i don't have any candles at the shop -yet.
PB Blast the remaining segment every hour or so and tink it with something good everytime - then heat - then use an easy out or extractor on it.
You "might" get a metal shaving in the pump - and you might have already gotten something into it - but its almost useless to you now anyhow like it sits - i'd go for it.
TDI pump head. Yes but No.
About 98% NO
Will bolt, probably run some, maybe sketchy at best without right injectors.
But its over your head and a waste of a more valuable pump. to be honest
if you can't get that piece out
i can look up a local'ish guy i know who had a couple/few 1.6 NA Pumps that he kept off running engines. He converts diesels to gassers.
Reply #17February 22, 2012, 08:41:01 am
slavik19
  • 59
« Reply #17 on: February 22, 2012, 08:41:01 am »
ive tried heating it up, with the welder will it turned red thers no more grip. it wont come out. the metal itself is very week.
yea if you can get me in contact with him i would really appreciate it
About 98% NO
Reply #18February 23, 2012, 01:13:42 pm
Baron VonZeppelin
« Reply #18 on: February 23, 2012, 01:13:42 pm »
I didn't even notice you had added some input in that re-quote.
But if you can get it that hot again - try shoving a candle into it/on to it.
Do that 2-3 times with heat - candle.
Then a left hand threaded easy-out (threads backwards [counterclockwise] into hole in the delivery valve) as it threads in it will lock inside and turn the delivery valve back out.
or-
a drive-in extractor tool - its like a 4 edged reamer you drive in with a hammer - then wrench it counterclockwise.
Just so happens i drove by where that guy had his shop yesterday, going somewhere else. The place is now vacant and for lease.
There is a NAPA right next door, they will probably know where he went.
Put a WANT TO BUY listing in parts section of NCdubs website.
Probably get some good leads or prospects there too.
Reply #19February 25, 2012, 06:22:26 pm
slavik19
  • 59
« Reply #19 on: February 25, 2012, 06:22:26 pm »
thanks everyone for your help.
met a guy names john west of charlotte.
he helped me out with a pump, bought it installed it. seems good. runs great so far.
thanks vwdiesel community!
also installed new speakers todays!
sounds better
now anyone want my old pump?
Reply #20February 25, 2012, 08:43:56 pm
  • 4393
« Reply #20 on: February 25, 2012, 08:43:56 pm »
How much for a broken pump that leaks?  Would you include the new O ring?
Reply #21February 25, 2012, 08:45:05 pm
slavik19
  • 59
« Reply #21 on: February 25, 2012, 08:45:05 pm »
new o ring is already installed. make me an offer. dont know how much to ask.
Reply #22February 26, 2012, 12:58:37 am
Baron VonZeppelin
« Reply #22 on: February 26, 2012, 12:58:37 am »
Glad you got hooked up local.
Good to hear its fixed and back on the road already.
Reply #23February 26, 2012, 08:54:08 am
slavik19
  • 59
« Reply #23 on: February 26, 2012, 08:54:08 am »
yea its cool.
going to try to make it to bww today at 1:30
Reply #24April 11, 2019, 08:11:42 pm
whealthy
  • 2
« Reply #24 on: April 11, 2019, 08:11:42 pm »
Hi,
I know this is an old post but does anyone know if there is a tutorial of any kind showing how to replace the injection pump head seal (o-ring) without taking the pump off the car and not completely removing the pump head?
Thanks in advance for your help. :)
Reply #25April 12, 2019, 12:14:21 am
  • 4393
« Reply #25 on: April 12, 2019, 12:14:21 am »
Tah Dah,   From the archives of this site but bounces you to another.
https://www.vwdieselparts.com/forum/viewtopic.php?t=5311&start=22
Andrew has great advice.
Reply #26December 01, 2019, 05:33:49 pm
whealthy
  • 2
Re: Injection Pump leaking o ring install tutorial
« Reply #26 on: December 01, 2019, 05:33:49 pm »
Does anyone have an updated link for this tutorial?  The link in the 4/2019 post appears to be dead
Thanks
Reply #27December 03, 2019, 05:20:16 pm
  • 3416
« Reply #27 on: December 03, 2019, 05:20:16 pm »
Sure, it was originally posted on this forum and then copied to the other linked address.
http://vwdiesel.net/forum/index.php/topic,4353.msg34061.html#msg34061
That does not cover replacing the little boost enrichment o-ring which is a somewhat involved process if resealing an enrichment equipped pump.
« Last Edit: December 03, 2019, 05:21:53 pm by libbydiesel »
Fixmyvw.com
