Author Topic: Hydraulic lifters and how to test 'em better?  (Read 18427 times)
Reply #15February 22, 2012, 10:25:08 am
Re: Hydraulic lifters and how to test 'em better?
« Reply #15 on: February 22, 2012, 10:25:08 am »
Good so far!!! I haven't drove it lots but it cranked less today than it did before.
I rebuilt the head myself, the whole problem was due to the valve stems protruding too close to the cam which I did know about the spec but for some reason I over looked it.
I totally enjoy driving this thing, cruises nice and quiet (compared to rabbit), has less power but I don't have the timing dialed in yet.
I'll keep you all posted on it.....
Reply #16February 22, 2012, 12:25:01 pm
rallydiesel
  • 1880
« Reply #16 on: February 22, 2012, 12:25:01 pm »
You say you rebuilt the head, did you also grind down the valve seats? Because that's the only way that the valve stems would be too long. A machine shop should check for this if they did the seats.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #17February 23, 2012, 10:36:12 am
« Reply #17 on: February 23, 2012, 10:36:12 am »
I did grind the seats and I did know about this measurement but I think I got interrupted in the middle of shortening them and skipped quite a few. Lesson learned the hard way, I wish I could blame a machine shop but I WAS the shop so I can't get my money back.
I have to mess with static timing and then timing advance and it'll be runnin' good. It likes to shudder a bit at low rpm/low power, when I pour on the coal it does fine until higher rpm then it sounds a little to marbly.
