Author Topic: AAZ pistons in ALH block  (Read 6287 times)
February 08, 2012, 06:02:30 am
RedRotors
  • 734
    • http://www.mikrotuning.com
« on: February 08, 2012, 06:02:30 am »
Any know if the AAZ pistona will fit in the ALH block ? I mean related to the piston pin height ? 1.9TD head will go on
top of that.
thanks,
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #1February 08, 2012, 06:06:04 am
Re: AAZ pistons in ALH block
« Reply #1 on: February 08, 2012, 06:06:04 am »
It works the other way, but you might have to use the rods from the AAZ.
Rereading the post I am not sure now. I know the 1z and AHU the swap is made, I am not sure on the ALH. I would still think if the rods were swapped with the pistons it would work. I think going the other way the engine needs honed as the rings are up higher on the TDI piston, but this way the ridge would still be below the TDI piston ridge.
Reply #2February 08, 2012, 06:21:01 am
RedRotors
  • 734
« Reply #2 on: February 08, 2012, 06:21:01 am »
honing the bloc won't be a problem, i was worry about the piston height, over the deck.. I don't want to shim the head
gasket..
91' VW Golf Country
-> www.hflox.com <-
Reply #3February 08, 2012, 06:22:00 am
410
  • 581
« Reply #3 on: February 08, 2012, 06:22:00 am »
It will work.  The center to center of aaz rods and alh rods is the same.
Reply #4February 08, 2012, 06:25:14 am
« Reply #4 on: February 08, 2012, 06:25:14 am »
Well then if the ALH and AHU have the same rods dimentions as the AAZ then it will work for sure.
I was just saying the ridge about rings as when you go from aaz to tdi the block almost always needs bored or honed with a machine. Going this way you should be able to do the drill and stone hone and be ok.
Reply #5February 08, 2012, 07:22:12 am
RedRotors
  • 734
« Reply #5 on: February 08, 2012, 07:22:12 am »
and the pin height in the both pistons are the same too ? Just making sure before spending $ on a new set of 1.9TD.
91' VW Golf Country
-> www.hflox.com <-
Reply #6February 08, 2012, 07:25:29 am
« Reply #6 on: February 08, 2012, 07:25:29 am »
I would trade you for the TDI pistons
Reply #7February 08, 2012, 08:54:41 am
rallydiesel
  • 1880
« Reply #7 on: February 08, 2012, 08:54:41 am »
I doubt the AAZ head will work on the ALH block. The ALH block is quite different from the AAZ/AHU.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #8February 08, 2012, 11:42:46 am
RedRotors
  • 734
« Reply #8 on: February 08, 2012, 11:42:46 am »
hehe that's the problem with discussion forum.. someone will say it works, some other will say it won't. I will buy the head and pistons and tryit by myself.
91' VW Golf Country
-> www.hflox.com <-
Reply #9February 08, 2012, 12:04:03 pm
rallydiesel
  • 1880
« Reply #9 on: February 08, 2012, 12:04:03 pm »
No I'm quite sure the ALH pistons are are interchangeable with the AHU and AAZ. I believe the top ring position is slightly different. But it's the head that won't work. You would need to use an AHU/1Z block with the AAZ head.
Reply #10February 08, 2012, 12:21:19 pm
« Reply #10 on: February 08, 2012, 12:21:19 pm »
I will trade you the 1.9 IDI pistons for the TDI and you can play with little expense.
Sounds like you need to look at the bottom of each head and see if the passages are the same.
ALH ripped from prothe's site
And he has no pic of the bottom, but seems to me the oil drain will be the only thing modified. This is his AHU head
« Last Edit: February 08, 2012, 12:27:11 pm by theman53 »
Reply #11February 08, 2012, 04:24:30 pm
410
  • 581
« Reply #11 on: February 08, 2012, 04:24:30 pm »
The pin height is the same.  The only difference is the top ring groove is higher on the alh compared to the aaz but deck heights are the same.  I've compared them side by side.
