Author Topic: VNT died, K24 swap now..  (Read 18262 times)
Reply #45February 15, 2012, 04:35:01 am
Re: VNT died, K24 swap now..
« Reply #45 on: February 15, 2012, 04:35:01 am »
I could never hear my turbo over the engine noise. But like I said before, my k24 started to spool around 2,000 and was full 22psi in everygear if I wanted to.
Reply #46February 15, 2012, 12:04:32 pm
« Reply #46 on: February 15, 2012, 12:04:32 pm »
now that ive been running it, it screams just about as much as my VNT..
and it BARKS every time you shift and your in the boost.. EVERY TIME. bark..
Reply #47February 15, 2012, 01:20:50 pm
« Reply #47 on: February 15, 2012, 01:20:50 pm »
thats interesting the big vnt advocate has had a change of opinion  ;D
but to be fair to the vnt your vanes were not operational.
i still feel kinda idiotic for not trying this sooner.. its a blessing in disguise if you ask me.. i like the K24 to be totally honest..
but i dont like that it barks soo much. it really worries me..
Reply #48February 15, 2012, 04:02:38 pm
« Reply #48 on: February 15, 2012, 04:02:38 pm »
More than one person told you that there was no advantage to running a VNT with stationary vanes over using an appropriately sized wastegated turbo.  However, an appropriately sized VNT with functional vanes is a humongous improvement over any wastegated turbo.
Do you have a full exhaust on it?  I had a K24 that barked significantly when I only had a downpipe on it.  The barking went away when I added the rest of the exhaust.
Reply #49February 15, 2012, 05:44:05 pm
« Reply #49 on: February 15, 2012, 05:44:05 pm »
My brothers T3 will bark with just the down pipe, is it a bad thing? what exactly is it that is happening?
Reply #50February 15, 2012, 06:14:22 pm
« Reply #50 on: February 15, 2012, 06:14:22 pm »
Perhaps when u let off the gas the exhaust side loses all drive pressure while some pressure is left on the intake side to reverse the flow of the turbo for a second. Just a thought
Reply #51February 15, 2012, 07:34:57 pm
« Reply #51 on: February 15, 2012, 07:34:57 pm »
it barks till its spooled down..
it will bark if you get on the boost, and then shift..
if you drive it like a granny, then it dont bark.
also has no downpipe..
Reply #52February 15, 2012, 07:35:56 pm
« Reply #52 on: February 15, 2012, 07:35:56 pm »
.. weiird.
Reply #53February 15, 2012, 08:09:34 pm
« Reply #53 on: February 15, 2012, 08:09:34 pm »
.. weiird.
yea.. if you speed shift, it only barks for a split second..
still barks tho.. more bark with more boost.. no boost = no bark..
Reply #54February 15, 2012, 09:41:27 pm
BillyWillicker
  • 111
« Reply #54 on: February 15, 2012, 09:41:27 pm »
Turbines work how guys?  pressure differential across the wheels, stock intake/exhaust = less pressure differential, open intake/exhaust = more pressure differential.  The more you hear it the better its working.
Reply #55February 16, 2012, 08:55:07 am
« Reply #55 on: February 16, 2012, 08:55:07 am »
so now that you like the k24, go even bigger try out that dodge turbo see how that runs, basically the same thing as joshs turbo but with the newer smaller faster spooling turbine wheel.  its basically what i am going to use but i am sticking with the vw .36 exhaust housing vs the dodge .48
