Author Topic: TT 65 Shore rear trans mount too hard?  (Read 4028 times)
February 05, 2012, 03:37:02 pm
wolf_walker
  • 1205
« on: February 05, 2012, 03:37:02 pm »
Anyone running one on an IDI?  Vibes bad?  Looking for less rocking on/off throttle.
They have that and a harder front snubber as well.
Mentat Text Two
Reply #1February 05, 2012, 04:25:03 pm
Re: TT 65 Shore rear trans mount too hard?
« Reply #1 on: February 05, 2012, 04:25:03 pm »
I was running a poly trans mount in my MK2 and after a week it was fine.
Reply #2February 05, 2012, 04:29:42 pm
wolf_walker
  • 1205
« Reply #2 on: February 05, 2012, 04:29:42 pm »
I figured poly would vibe like hell and then rip back there, seems like the gasser guys were tearing them up not to long ago.
Hmm.
TT makes an 80 shore as well I think in rubber.  That's poly hardness range I believe.
Mentat Text Two
Reply #3February 05, 2012, 08:48:35 pm
mystery3
  • 774
« Reply #3 on: February 05, 2012, 08:48:35 pm »
I ran prothane poly all around for a while on a mkI, I ended up changing the front and rear mounts to rubber to lessen the nvh. I imagine if you were running front and rear poly and had rubber sides it might not be too bad? Do you have an interior, carpet, pad etc?
Reply #4February 05, 2012, 08:59:38 pm
wolf_walker
  • 1205
« Reply #4 on: February 05, 2012, 08:59:38 pm »
What's left of the interior after 600K and change, yeah.  It ain't quiet as it is, but it's alright.
I think I'll try the 65 or 80 rear mount.  And find something to coat it in to keep the oil off it.
Mentat Text Two
Reply #5February 05, 2012, 09:15:43 pm
mystery3
  • 774
« Reply #5 on: February 05, 2012, 09:15:43 pm »
I've a leaky slider so I ripped my soggy/moldy carpet out a while back. I'm thinking in the future about laying some dynamat and rolling truck bedliner over it. It's pretty loud but I like loud/rattly old stuff so it works for me.
Reply #6February 05, 2012, 09:17:42 pm
wolf_walker
  • 1205
« Reply #6 on: February 05, 2012, 09:17:42 pm »
Slider been leaking in mine for a decade.  Still metal under there somehow.  I don't think I could stand it without carpet.
Mentat Text Two
Reply #7February 06, 2012, 04:35:44 am
« Reply #7 on: February 06, 2012, 04:35:44 am »
I read rear as trans mount... I have a poly insert for the rear and it was horrible on the vibration. I have a G60 mount for the front, the poly trans mount, and a stock rear. That is good, I would like it to be stiffer, but the poly mount in the rear was way too much. I drove it 1/2 mile and back then took it out. During driving it was awesome, but at idle it was insane. You couldn't see out of the mirrors. The rear mount is the one that transfers all the vibration.
This is MK2 correct, as that is what mine is.
Reply #8February 06, 2012, 05:04:53 am
wolf_walker
  • 1205
« Reply #8 on: February 06, 2012, 05:04:53 am »
I'm sorry, its an A1 Caddy.
And I meant the rear trans mount. :)
Mentat Text Two
Reply #9February 06, 2012, 05:46:35 am
« Reply #9 on: February 06, 2012, 05:46:35 am »
Well, MK1 is completely different. I have riden in my buddies 8v gasser with full poly and it wasn't as bad as my diesel with the poly insert and trans mount. You will have to get advice from someone that did it in a diesel mk1, sorry.
Reply #10February 06, 2012, 08:25:22 am
« Reply #10 on: February 06, 2012, 08:25:22 am »
i swapped in just the rear mount and it vibrated alot all other mounts were stock on a basically stock td in a mki.  i have heard u can do poly side and front mounts but not the rear in a mk1.  i'm curious how the bfi mounts would feel.
Reply #11February 06, 2012, 02:24:08 pm
wolf_walker
  • 1205
« Reply #11 on: February 06, 2012, 02:24:08 pm »
Poly or stiff rubber you used?
Mentat Text Two
Reply #12February 07, 2012, 05:13:25 pm
« Reply #12 on: February 07, 2012, 05:13:25 pm »
red poly, someone or vortex used a gm transmount and loves it
Reply #13February 07, 2012, 07:23:02 pm
« Reply #13 on: February 07, 2012, 07:23:02 pm »
I have a writeup on here about poly mounts, of course they're probably harder than any rubber mount but you'll get an idea.
http://www.vwdiesel.net/forum/index.php?topic=25324.0
Rear trans mount was terrible, I got like halfway home and turned around and went back to the shop to put the rubber one back in. Way too noisy at idle and certain other rpm. Front mount got used a couple days, but cruising was fine but the idling was really bad and I couldn't stand it. Shifted nice though.......
Reply #14February 07, 2012, 07:25:55 pm
wolf_walker
  • 1205
« Reply #14 on: February 07, 2012, 07:25:55 pm »
I'm still of the opinion that the A1 mount setup just leaves a lot to be desired, even on the gassers I've had.
I appreciate the info guys, I'll spring for the stiffer TT rubber one and see what's up I guess.
Mentat Text Two
