Author Topic: ultimate-ish 1.6td build?  (Read 17865 times)
Reply #15February 06, 2012, 10:36:13 pm
Baron VonZeppelin
Re: ultimate-ish 1.6td build?
« Reply #15 on: February 06, 2012, 10:36:13 pm »
The downside of the exhaust - is the manifold itself.
Here is an idea ...
Reply #16February 07, 2012, 05:12:50 pm
« Reply #16 on: February 07, 2012, 05:12:50 pm »
what ever u do i recommend all arp hardware, and doing as much as you possibly can to make the head flow, i believe that is one of the biggest hurdles on these engines, small valves and ***ty port design(mostly on the exhaust side.)  as far was what turbo is good, theres many different ones, depends what you really want and what your power goals are.
TREVOR!! just who i was looking for..
i need your turbo wisdom.. my VNT is dead.. probably not going to replace it with a VNT unless i get one for a song..
anyways, i have at my disposal:
a T2 off a nissan gasser
a T3 off a 2.5 CHRY gasser (much larger T3 than the stock diesel unit)
a T3 off a 2.3 Pug TD
a TD04 off a 2.2 CHRY
a K24 off a VW 2.0TD
a K26 off an Audi quattro
a T4 off a 4-53 Detroit diesel..
i know that doesnt tell you SH## without numbers and stuff, but what do you think would be the best turbo(s) to replace mine with?
i was just getting ready to go compounds.. now my VNT is not rebuildable.. over 1/4" of radial shaft play, and almost 1/8" of axial play..
it grinds, scrapes, spools and unspools on its own, and even seized up at one point.. and MAN, did it puke its guts all over my engine bay..
t2 probably be fine for a small turbo but that is all
dodge t3 is the same as powered by spearcos turbo except for that it has the newer turbine wheel(same as vws and basically any car that got a t3 starting after 1983 or so)  the new turbine wheel had a smaller in and was lighter so it spooled up faster this what a turbo company told me.  its a 45 trim t3 with .48 a/r exhaust housing
pug t3 http://www.turbominis.co.uk/forums/index.php?p=vt&tid=689  assuming this forum is correct then this turbo is a 40 trim t3 with a .36 a/r exhaust housing(same as vw but vw is a 35 trim compressor) and this turbo has the older larger turbine wheel.
td04 do u mean te04? if some my friend has one on his rabbit it runs really well but he doesn't have a governor mod or anything and he was having trouble with the wastegate and clutch, so aside from that it is way faster now but still nothing really conclusive, from the compressor map tho it looks like a good mid sized turbo, but the dodge t3 compressor looks way better.
k24 from audi, from what i understand its the same as vw, good turbo for a 1.6 but we all know its limits
k26 off an audi, good turbo but not on a diesel cause its not efficient at high boost pressures only at lower boost higher flow.
t4, u know that things too big haha.
if i were you i'd go with the dodge t3 or the pug t3, dodge has the bigger compressor so better flow and better compressor map, but the pug has the smaller a/r turbine housing so it would spool faster assuming the larger turbine wheel doesn't hurt spool that much.  u could even do a hybrid, and slap the dodge compressor on the pug exhaust side, easy as well.  or even try the dodge compressor on the t2 exhaust side.  i don't know the specs of the t2 but if u look how much hp they can get from them stock u can get an idea of how much the t2 exhaust flows, if its around 200hp then itd be a good match on the dodge compressor.
but i will warn you, i just understand turbo sizing, i dont have experience trying all this stuff.  so no real world reviews(except on te04 and k24)  we all know that not much research has been done in the way of vw diesel turbos, so it still all up in the air and an experiment
Reply #17February 07, 2012, 07:48:30 pm
Newschooldiesel
  • 14
« Reply #17 on: February 07, 2012, 07:48:30 pm »
might as well experiment on mine to. im up for compounds  :o
1984 Rabbit - 1.6l Turbo equipped in the makins...
Reply #18February 08, 2012, 08:57:27 am
« Reply #18 on: February 08, 2012, 08:57:27 am »
My guy said the stock exhaust wasn't that bad. There wasn't much to gain flow wise, maybe different ports all together would make the difference. Here is the flow chart of my head in stock and ported conditions. Intake gained almost 30% and exhaust around 10%.
i have heard the same thing about the gas sized valves of 33mm that the stock sized is actually all thats worth going to because any larger and the port of the head is actually the restriction not the size of the valve, and since the gas and diesel heads are so similar (especially the heron 1.6gti heads) i would think there is something to gain with going to the gasser sized valves and heavy porting.  heron had 40mm intake and 33mm exhaust, perhaps we could benefit from these sized valves, or even just 38 and 33.
Reply #19February 08, 2012, 08:59:44 am
« Reply #19 on: February 08, 2012, 08:59:44 am »
Yeah, what is our stock size in the 1.6 and 1.9 IDI's? I will probably go bigger next time around.
Reply #20February 08, 2012, 10:37:14 am
UnderPSI
  • 109
« Reply #20 on: February 08, 2012, 10:37:14 am »
1.6 has 34 and 27.
Suzuki Samurai 1.6
Reply #21February 08, 2012, 10:37:24 am
« Reply #21 on: February 08, 2012, 10:37:24 am »
1.6 is 34mm in 31mm ex
1.9 is 36mm in 31mm ex
Tdi is same as aaz but slightly different lengths
It's be interesting to see how they'd run with these mods. I talked to my machinist and I asked if a valve is close in length within 1-3mm if they'd work by shimming and trimming the underside of the lifter some but he said no its gotta be close like less than .5mm but he said custom valves are not so bad 30-40 a valve which is bad but not outrageous certainly affordable. I wonder if the heron valves would work u can get a nice set from Bildon with stems cut down near the valve head for better flow and could even use the taped gasser guides
Reply #22February 08, 2012, 10:47:37 am
92EcoDiesel Jetta
« Reply #22 on: February 08, 2012, 10:47:37 am »
and if your going to try and find a Pug 505TD pump, good luck. they are more rare than a diesel auto starter.. only reason i said anything about them, is because i have one, and its ALMOST set up to run on a VW with no mods..
Has anyone actually put a Peugeot 505 TD pump or parts from the Peugeot pump in a VW 1.6 TD? What were the results?
Reply #23February 08, 2012, 12:16:51 pm
« Reply #23 on: February 08, 2012, 12:16:51 pm »
My air cooled guy gets stainless blanks and undercuts them himself. That is where I am going to go. IIRC 3 years ago my valves cost under 8.00 each.
Reply #24February 09, 2012, 01:55:01 am
Alcaid
  • 549
« Reply #24 on: February 09, 2012, 01:55:01 am »
Do you know what material his blanks are made of?
'10 VW Passat 1.6TDI Highline
Reply #25February 09, 2012, 05:22:21 am
« Reply #25 on: February 09, 2012, 05:22:21 am »
Reply #26February 09, 2012, 07:47:44 am
« Reply #26 on: February 09, 2012, 07:47:44 am »
not that im aware of.. when i posted up that i had a Pug pump, and wanted info about it, i got nothing.. nobody knows JACK about the Pug pump..
should work fine once you deal with the bracket issues, and change the delivery valves..
Reply #27February 09, 2012, 10:22:21 am
Alcaid
  • 549
« Reply #27 on: February 09, 2012, 10:22:21 am »
Even the stock valves are stainless! 21-4N, 23-8N, 21-12N, Nimonic 80A, Inconel and so on are all different "upgraded" stainless materials used in performance valves with each their own specifications, and the list propably goes on so stainless does not describe the valves limitations at all.
« Last Edit: February 09, 2012, 03:30:39 pm by theman53 »
Reply #28February 09, 2012, 03:28:08 pm
« Reply #28 on: February 09, 2012, 03:28:08 pm »
The material is stainless. The GRADE of stainless I do not know and won't know for a long while as I don't have a head yet to ask him about.
« Last Edit: February 09, 2012, 07:04:45 pm by theman53 »
