Author Topic: If I use this (slightly damaged) cam....  (Read 3607 times)
February 02, 2012, 03:57:21 pm
hippiekiller
  • 73
« on: February 02, 2012, 03:57:21 pm »
...whats the worst that could happen? Trying to do an emergency overhaul on my parts head....
 No damage to the journal or anything, 'bearing' surface looks good, would mostly just be worried about proper lubrication...
Thanks.
« Last Edit: February 02, 2012, 03:59:35 pm by hippiekiller »
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #1February 02, 2012, 04:41:34 pm
maxfax
  • 2126
Re: If I use this (slightly damaged) cam....
« Reply #1 on: February 02, 2012, 04:41:34 pm »
You should be fine with that..   Lots of people out there have run cams like that with no ill effects..
Reply #2February 02, 2012, 07:51:59 pm
410
  • 581
« Reply #2 on: February 02, 2012, 07:51:59 pm »
x2.  I've come close to doing the same thing by forgetting the cam locking tool before turning it over.  I'm sure it'll be fine.
Reply #3February 02, 2012, 08:52:31 pm
Powjetta
  • 152
    San Diego CA
« Reply #3 on: February 02, 2012, 08:52:31 pm »
Mine looks like that now, and I have put 30K miles on it like that.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #4February 03, 2012, 07:22:28 am
hippiekiller
  • 73
« Reply #4 on: February 03, 2012, 07:22:28 am »
Right on, just needed a second opinion....
What kind of sealant does one use on the cam seal end?
95 jetta, 2"lift
Reply #5February 04, 2012, 01:30:08 am
Mark(The Miser)UK
  • 1557
« Reply #5 on: February 04, 2012, 01:30:08 am »
At least you won't be being clever like I assume, the PO thought he was, and using the slot as a tightening lever ;D
Sealant? Try a smear of engine oil.
Mark-The-Miser-UK
Reply #6February 04, 2012, 03:21:48 am
regcheeseman
  • 714
« Reply #6 on: February 04, 2012, 03:21:48 am »
I did that to a cam two weeks ago when I forgot the locking bar was still in  ::)
I used a small grinding disc to put a chamfer on the leading edge of the cracked piece to prevent it from gouging into the cam retainer caps.
Reply #7February 04, 2012, 06:02:40 am
hippiekiller
  • 73
« Reply #7 on: February 04, 2012, 06:02:40 am »
I noticed when I dissassambled it that there was some sealant applied around the cam seal and on the first bearing retainer (not on the journal obviously) Is this normal?
95 jetta, 2"lift
Reply #8February 04, 2012, 09:00:59 am
Powjetta
  • 152
    San Diego CA
« Reply #8 on: February 04, 2012, 09:00:59 am »
I use the RTV mostly at the corners and transitions of that cam plastic/ rubber piece, nothing inside and no marks on the seal with several VC changes.
Reply #9February 04, 2012, 06:26:38 pm
RadoTD
  • 513
    Stage WTF
« Reply #9 on: February 04, 2012, 06:26:38 pm »
Haha, I always wondered why my cam had that chunk missing! Now I know  ;)
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
