Author Topic: Lift pump and Injector upgrade for AAZ  (Read 15589 times)
Reply #15February 06, 2012, 11:13:34 am
wdkingery
  • 494
Re: Lift pump and Injector upgrade for AAZ
« Reply #15 on: February 06, 2012, 11:13:34 am »
Please continue on about the lift pumps; I've noticed quieter clatter and slightly elevated operating temps with my new cocktail, so I'd like to find the cheap lift pump answer
Reply #16February 08, 2012, 12:07:28 pm
damac
  • 531
« Reply #16 on: February 08, 2012, 12:07:28 pm »
Here are a couple pics of carrier faucet pump.  I have heard from multiple people that these pumps do NOT like cocktails and they are meant to be constant duty diesel pumps.  This sucker has no problem priming the dual tanks on my old f250.  Also didn't seem to pose any issues on the jetta during the short week I ran it on there.
http://smg.photobucket.com/albums/v44/kellyass/?action=view&current=P2081358.jpg
http://smg.photobucket.com/albums/v44/kellyass/?action=view&current=P2081360.jpg
1985 turbo diesel jetta
Reply #17February 08, 2012, 06:35:25 pm
« Reply #17 on: February 08, 2012, 06:35:25 pm »
the universal SHAKER pumps you get at the auto parts stores are fine for cocktails.. there are no rubber pieces in them, just some springs, a plunger, and a couple check valves..
ive been running one in my diesel for a very long time.. its just an electric fuel pump, meant to feed a carburator, but rigged up under my Jetta, and pumping diesel..
Reply #18February 08, 2012, 09:39:40 pm
tdotdub
  • 52
« Reply #18 on: February 08, 2012, 09:39:40 pm »
what PSI is it pumping?
87 Audi 5000S Quattro Turbo Diesel (the car I want to light on fire everyday)
99 Beetle TDI (the beater)
99.5 Cabrio  (the innocent one)
Reply #19February 09, 2012, 11:35:20 am
wdkingery
  • 494
« Reply #19 on: February 09, 2012, 11:35:20 am »
Autozone. Com has a few different ones.. Around 4-7 psi max.. Sounds good! Is it OK to run about 5 psi @ my IP all the time?
Reply #20February 09, 2012, 02:44:37 pm
« Reply #20 on: February 09, 2012, 02:44:37 pm »
you can run like, oh, 30 psi safely to your injection pump.. i think thats what giles and tyler fed a pump with..
be sure it has a flow rating of atleast 15 GPH.
Reply #21February 11, 2012, 09:20:53 am
ToddA1
  • 434
« Reply #21 on: February 11, 2012, 09:20:53 am »
What's the purpose of the lift pump if your IP is good?  I thought you'd only want to use one if your pump isn't priming properly.
-Todd
Reply #22February 11, 2012, 04:22:47 pm
« Reply #22 on: February 11, 2012, 04:22:47 pm »
-Todd
if you want power, then vacuum at the pump inlet is bad.. it makes the timing advance later than if the pump had pressurized fuel waiting for the vane pump to inhale..
basically, is it easier to suck fuel thru a 20ft drinking straw, and fuel filter? or is it easier to let the fuel simply flow out of the 20ft drinking straw, and be delivered to the pump, rather than be pulled to the pump..
you can STARVE the pump of fuel in the higher rpms, and with a lift pump, it doesnt happen. when the engine is revved up, the vane pump is making LOTS OF VACUUM, and it can aerate the fuel in the lines from vacuum. if you have a lift pump, and any amount of positive pressure, the fuel will NOT AERATE..
Reply #23February 12, 2012, 07:16:34 am
ToddA1
  • 434
« Reply #23 on: February 12, 2012, 07:16:34 am »
Good info.  Thanks!
-Todd
Reply #24February 23, 2012, 01:33:12 pm
wdkingery
  • 494
« Reply #24 on: February 23, 2012, 01:33:12 pm »
Well I installed a lift pump off a Chevy diesel for $8 from the junkyard.. Ooo wee couldn't be happier! Bucking is gone, multiple great effects. Shoulda done this sooner or it should have come stock!
Reply #25March 05, 2012, 03:01:20 pm
Big Daddy Roth
  • 298
« Reply #25 on: March 05, 2012, 03:01:20 pm »
So is there an upgrade for AAZ nozzles?
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #26March 08, 2012, 03:19:19 pm
monomer
  • 414
« Reply #26 on: March 08, 2012, 03:19:19 pm »
Walbro fpr is made for diesel and is biodiesel ready. I think mine ran 100usd.
theres no way i would regulate 50 (digi) or 100 (cis) psi with a simple regulator.. is it made for such high pressure?
Walbro makes a line of lift pumps perfect for our application: http://www.walbro.com/producthlt.aspx
It's been mentioned here before, I don't think I'm the only one (planning to) run one. Mine was <100USD, but I ordered it so long ago I can't remember.
You won't need a regulator, ditch the tank pump if that's what you're talking about. It's likely to go, as all of it's rubber seals will swell with diesel (around here most/all diesel is B5 - 5% bio)
www.michiganvw.org
Reply #27March 08, 2012, 06:51:55 pm
« Reply #27 on: March 08, 2012, 06:51:55 pm »
giles reccomends the 6.5TD lift pump.. there around 50 bucks new, iirc..
Reply #28March 08, 2012, 09:44:14 pm
tdotdub
  • 52
« Reply #28 on: March 08, 2012, 09:44:14 pm »
a 6.5 td what?gm ford? and does it just drop into the tank no modifications other than maybe different hose size?
Reply #29March 09, 2012, 04:25:12 am
« Reply #29 on: March 09, 2012, 04:25:12 am »
GM 6.5, it is inline not in tank.
