Author Topic: 7" LED Headlamps???  (Read 3866 times)
January 20, 2012, 02:10:51 pm
Newschooldiesel
  • 14
1984 Rabbit - 1.6l Turbo equipped in the makins...
Reply #1January 20, 2012, 08:28:29 pm
mystery3
  • 774
Re: 7" LED Headlamps???
« Reply #1 on: January 20, 2012, 08:28:29 pm »
That advert is from three years ago so they may be available. Does anybody care about DOT approved lights? Do cops or inspectors ever check your headlamps for the DOT approval?
Reply #2January 23, 2012, 09:27:04 am
clbanman
  • 705
    Cambridge, Ontario
« Reply #2 on: January 23, 2012, 09:27:04 am »
Click on the link to the online catalog page and it says they have DOT approval.   It's just a different type of bulb, not brighter per se.   Available at Amazon among others:  http://www.amazon.com/Truck-Lite-27250C-Round-Headlamp-Inches/dp/B002IFRROM
I've been told that one problem with most LED lights is that they don't put out enough head to melt snow or ice which can cause problems in the northern part of our world.   Not sure about headlights, but I know local truckers who switched their trailers to LEDs and then switched back because they couldn't keep their brake and turn signal lights clear.
Calvin
91 VW Golf 1.6NA 5spd
Reply #3January 23, 2012, 10:48:02 am
guy plain
  • 121
« Reply #3 on: January 23, 2012, 10:48:02 am »
 that is true....i have 6 years of stump to dump logging all over BC and Aberta mostly winter work.....and you really dont want LED lights on your trailer.....they get snowed over very fast....its a real pain for any one comming behind you....at night your almost invisable....
Reply #4January 23, 2012, 12:26:57 pm
« Reply #4 on: January 23, 2012, 12:26:57 pm »
good discussion guys.. i didnt even have to participate in this to make a decision against them..
Reply #5January 23, 2012, 12:34:01 pm
« Reply #5 on: January 23, 2012, 12:34:01 pm »
Military and utilities use them because they work.
I put some 18W LED worklights on an electric golf cart, and they get pretty warm despite a hefty aluminum heat sink.  They are about as bright as a normal low beam headlight, and have much wider dispersion.
Reply #6January 23, 2012, 05:09:29 pm
Newschooldiesel
  • 14
« Reply #6 on: January 23, 2012, 05:09:29 pm »
I really like the type of light they put out. Ill probly just get some led fogs and call er' good
