General Information
Upgrades (non engine related )
02M vs 0A8 6-speed manual gearbox - VSS??
Topic: 02M vs 0A8 6-speed manual gearbox - VSS?? (Read 10780 times)
January 19, 2012, 06:32:12 am
X@V
January 19, 2012, 06:32:12 am »
I was buying a 0A8 gearbox (Code FSM, from a Skoda Fabia VRS). It's 99% same as the 02M but without the VSS!
I removed the VSS from my 02M and I saw how it's made: 7 notch on the diff casting.
Does someone know if the diff is the same inside the 0A8? I could drill the case and put the 02M VSS. If not, I'll install an external VSS.
Thanks
Last Edit: January 20, 2012, 09:24:39 am by X@V
January 19, 2012, 09:46:53 pm
mystery3
Re: 02M vs 0A8
January 19, 2012, 09:46:53 pm »
Are you on motorgeek? I imagine they might have some more info always trying to figure out what to use in place of broken 01A's and whatnot.
January 20, 2012, 06:38:50 am
X@V
Re: 02M vs 0A8
January 20, 2012, 06:38:50 am »
Why 01A?
January 20, 2012, 08:36:46 pm
mystery3
Re: 02M vs 0A8 6-speed manual gearbox - VSS??
January 20, 2012, 08:36:46 pm »
I'm not really a transmission guy but I think the 01a is fragile. I was just saying the people on motorgeek.com know more about transmission swaps than do people here, or at least there is more discussion of transmission related items aside from ratios.
January 23, 2012, 06:31:37 am
X@V
January 23, 2012, 06:31:37 am »
I didn't talk about 01A!!!
January 23, 2012, 06:33:31 am
X@V
January 23, 2012, 06:33:31 am »
0A8 bellhousing
02M bellhousing
January 23, 2012, 07:54:17 am
January 23, 2012, 07:54:17 am »
I don't know if the vss will fit as I never have tried that swap. If the cases are the same then it "should" fit I would think. Maybe some machining required if it is different??? I am guessing.
It could just be the picture, but is the starter hole higher on one than the other?
Round 2
January 23, 2012, 08:47:05 am
X@V
January 23, 2012, 08:47:05 am »
Starter hole is same...
There's the "plate" where the VSS sits on the 02M but not any hole.
I think I'll use an external VSS with a custom trigger wheel.
January 23, 2012, 10:14:09 pm
mystery3
Re: 02M vs 0A8
January 23, 2012, 10:14:09 pm »
Quote from: X@V on January 20, 2012, 06:38:50 am
Why 01A?
I was referring to it as an example. %90 of the people on this site run 020 don't have any other options and don't know anything about skoda gearboxes. I was attempting to refer you to a site which may contain more insight on obscure transmission swaps. Where did you get a skoda box on this side of the planet anyway?
January 24, 2012, 05:16:18 am
X@V
January 24, 2012, 05:16:18 am »
I got it from UK. It was on a Fabia VRS 2004 PD130
General Information
