Author Topic: camshaft question - 1.6 mechanical head  (Read 6177 times)
Reply #15January 20, 2012, 04:19:45 am
Re: camshaft question - 1.6 mechanical head
« Reply #15 on: January 20, 2012, 04:19:45 am »
if ur talking about what i think you're talking about, many just take material off the top of the valve
Reply #16January 21, 2012, 06:46:44 pm
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
« Reply #16 on: January 21, 2012, 06:46:44 pm »
Thanks for the inputs guys.   I had the bottom end done & head rebuilt about 6months ago here in Seattle, but not started yet due to turbo build complexity and a health issue.   I seem to recall that the machine shop said that they used a "TDI cam" and made the changes necessary for use in a mechanical lifter engine - - is this even possible?   Maybe I should do a check of valve lash, can I check each cylinder at TDC with a feeler gauge or how is it done?
The crank turns over very easy when rotated by the sprocket bolt clockwise, except for normal cylinder compression action.  Since it's been stored ~ 6 months in a dry garage, do I need to lube the cylinders before initial start after rebuild?
Reply #17January 22, 2012, 06:28:00 am
« Reply #17 on: January 22, 2012, 06:28:00 am »
From what I understand the tdi cams are not as good
Reply #18January 24, 2012, 05:39:18 am
« Reply #18 on: January 24, 2012, 05:39:18 am »
out of all the diesel cams, the 1.6TD has the hottest stock grind.
