Author Topic: camshaft question - 1.6 mechanical head  (Read 6193 times)
January 16, 2012, 12:54:10 pm
Rock3tman
  • 113
    prev: 60typ2, 68pickup, 79rabbitD. now: 83jettaTD
« on: January 16, 2012, 12:54:10 pm »
...What is my choice for a replacement camshaft for a 1983 CY turbodiesel - it has mechanical lifters.  The original german one has worn lobe ramps and journals.
thanks
Reply #1January 16, 2012, 01:05:20 pm
Re: camshaft question - 1.6 mechanical head
« Reply #1 on: January 16, 2012, 01:05:20 pm »
thanks
the only replacement im aware of is another solid lifter VW diesel cam.. either from a 1.5D, or a 1.6 n/a or TD..
dont even try, or think about dropping a gasser cam in there, it wont ever work. the snout is wrong, along with the grind.. the valves would be in constant contact with the pistons..
Reply #2January 16, 2012, 03:25:34 pm
wdkingery
  • 494
« Reply #2 on: January 16, 2012, 03:25:34 pm »
thanks
Booooo you mean you cannot get a more aggressive / aftermarket cam? People are always posting crazy links.. Maybe this could be the cam thread.
Reply #3January 16, 2012, 03:29:43 pm
« Reply #3 on: January 16, 2012, 03:29:43 pm »
thanks
you can get a giles cam, or something like that, but i dont think they offer a model for the solid lifter head..
an aftermarket cam should be pretty much LAST on your list of mods.. installing one on a completely stock engine wont yield nearly as much power gain as if you installed it in a heavily modified engine..
like, after a giles pump, and bigger turbo, or compound setup, and on and on.. then its time to upgrade the cam.
Reply #4January 16, 2012, 03:37:45 pm
« Reply #4 on: January 16, 2012, 03:37:45 pm »
Not only that but these are diesel engines.. there is not much to be had in the ways of doing a camshaft.
Reply #5January 17, 2012, 07:58:44 am
« Reply #5 on: January 17, 2012, 07:58:44 am »
like i said, it should be the LAST upgrade.. when you are all out of other options, and need to squeeze every single .01hp out of your engine..
Reply #6January 17, 2012, 08:07:16 am
« Reply #6 on: January 17, 2012, 08:07:16 am »
Yes, if you re-read what I posted I was agreeing with your statement. ;)
The pistons literally chase the valves back up into the head on the exhaust stroke, and the valve chases the piston down on an intake stroke. There is only a few thou clearance, and it is why stuff gets SMA#$@#%SHED when the timing belt slips or breaks.
Reply #7January 17, 2012, 08:28:35 am
« Reply #7 on: January 17, 2012, 08:28:35 am »
i was not saying you were not agreeing...
i know you were.. you dont disagree with me just to argue about something, i know that much. you may like the debate, but not a pointless one  ;)
Reply #8January 17, 2012, 08:31:36 am
« Reply #8 on: January 17, 2012, 08:31:36 am »
I love debating, from debating comes understanding. Thank-you for the great mind-stimulation ;) :-* lol
Reply #9January 17, 2012, 09:06:03 am
UnderPSI
  • 109
« Reply #9 on: January 17, 2012, 09:06:03 am »
A guy was making a custom grind in Canada a few years ago.
Suzuki Samurai 1.6
Reply #10January 17, 2012, 10:16:30 am
MJF
  • 581
« Reply #10 on: January 17, 2012, 10:16:30 am »
Adjusting valve lash is a little problem with regrinded mech cam.
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #11January 18, 2012, 02:40:31 pm
UnderPSI
  • 109
« Reply #11 on: January 18, 2012, 02:40:31 pm »
Lash caps.
Suzuki Samurai 1.6
Reply #12January 19, 2012, 02:36:21 am
MJF
  • 581
« Reply #12 on: January 19, 2012, 02:36:21 am »
Yep. Cam grinder have to know lash cap thickness before grinding, so he can grind base circle to correct dimension.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
Reply #13January 19, 2012, 06:46:41 pm
UnderPSI
  • 109
« Reply #13 on: January 19, 2012, 06:46:41 pm »
uh... that's a negative. Grind the lash cap to the thickness you desire.
Suzuki Samurai 1.6
Reply #14January 19, 2012, 09:10:41 pm
MJF
  • 581
« Reply #14 on: January 19, 2012, 09:10:41 pm »
Oh yeah, that could be easier. Didnīt think of that ;D
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
