Author Topic: 5 spd man trans problem i think  (Read 5461 times)
January 16, 2012, 10:54:51 am
jpedro
  • 137
« on: January 16, 2012, 10:54:51 am »
hey there so i belive i have a problem with my transmission, not sure though.  my car when driving on snow or ice and gear 1-5 or even reverse, only the pass side tire spins, which really leaves me stuck sometimes going up hill. is this normal? or is something really wrong? simple fix or just wat it is?  if i turn the wheels back and forth left to right vis versa the drivers side will spin once in a while but this is a pain in the a*s as i can hardly make it up hills with snow or ice on them with winter tires.  ive got no idea which trans it is other then a 5 spd manual behind a 1.6TD
1990 VW Jetta 1.6L TD 235000kms Custom cold air intake and Custom 3" straight pipe
1992 Ford F250 7.3L IDI custom everything you can possibly think of. ( my braging rights are live with this toy)
Reply #1January 16, 2012, 10:57:46 am
Re: 5 spd man trans problem i think
« Reply #1 on: January 16, 2012, 10:57:46 am »
exact same thing my car was doing last night.. use ZERO throttle to take off.. that works better, then it doesnt just blow the pass side tire off.
Reply #2January 16, 2012, 12:37:30 pm
Swartzvw
  • 53
« Reply #2 on: January 16, 2012, 12:37:30 pm »
Thats normal, thats why they invented limited slip differentials  ;D
84 VW Rabbit w/ VNT 17
87 VW Jetta GL
Reply #3January 16, 2012, 12:39:04 pm
jpedro
  • 137
« Reply #3 on: January 16, 2012, 12:39:04 pm »
Is there anything you can do to make it not as slippy lol or am i sol
Reply #4January 16, 2012, 12:43:00 pm
« Reply #4 on: January 16, 2012, 12:43:00 pm »
short of splitting the trans and installing an LSD, or welding up the spider gears, your SOL.. i dont think they make a mini-slip kit anymore..
try taking off without giving it any throttle. and dont take off on hills. start out on flat ground and attempt to kinda coast up the hills, dont power down trying to go up them, it just makes you spin worse.
and in ice, once your spinning, it does not get better.. it just keeps spinning till your tire melts the ice away down to the road..
Reply #5January 16, 2012, 12:44:02 pm
Swartzvw
  • 53
« Reply #5 on: January 16, 2012, 12:44:02 pm »
Either get better tires, chains or an LSD. LSD's are expensive though.
87 VW Jetta GL
Reply #6January 16, 2012, 12:47:02 pm
BillyWillicker
  • 111
« Reply #6 on: January 16, 2012, 12:47:02 pm »
Check the left front brake.  Other than that you can do a 20%, 80% or LSD differential.
Reply #7January 16, 2012, 12:47:18 pm
« Reply #7 on: January 16, 2012, 12:47:18 pm »
what he said!
better tires help out immensely..
and if its that slick out, you should have a set of chains..
Reply #8January 16, 2012, 12:53:38 pm
jpedro
  • 137
« Reply #8 on: January 16, 2012, 12:53:38 pm »
Haha do i dare ask what a lsd is lol sounds like a drug :p but no ill just leave it as is. I suppose. Just wanted to make sure my trans wasnt fubared
Reply #9January 16, 2012, 01:01:49 pm
Swartzvw
  • 53
« Reply #9 on: January 16, 2012, 01:01:49 pm »
Limited Slip Differential
87 VW Jetta GL
Reply #10January 16, 2012, 01:03:36 pm
DieselBalz
  • 301
« Reply #10 on: January 16, 2012, 01:03:36 pm »
Limited Slip Differential. Think of it like positraction. If one wheel slips, the other spins/ grips.
Reply #11January 16, 2012, 01:03:51 pm
« Reply #11 on: January 16, 2012, 01:03:51 pm »
its fine. its just an open differential. any open differential will do this, given the right conditions..
if NO tires were spinning, then you would be having severe issues.. but being that power still gets to the tires, its fine.
Reply #12January 16, 2012, 01:21:11 pm
shwak23
  • 417
    • Blackdog Junkyard
Re: Re: 5 spd man trans problem i think
« Reply #12 on: January 16, 2012, 01:21:11 pm »
I do fine in the winter in Maine with studded snow tires. I rarely slip much and as long as im not driving on a frozen river of ice I can get anywhere.
Sent from my DROID X2 using Tapatalk
Reply #13January 16, 2012, 02:22:07 pm
« Reply #13 on: January 16, 2012, 02:22:07 pm »
i gots a solution for ya..
put a studded tire on the passenger side, or chain it up!
lmao..  ;D
Reply #14January 16, 2012, 03:13:15 pm
jpedro
  • 137
« Reply #14 on: January 16, 2012, 03:13:15 pm »
Haha i do have studded tiress on it just was checkin to see if my trans was normal is all goin to our ski hill is deffenatly a chor
