Author Topic: Motor Oil  (Read 10263 times)
January 15, 2012, 06:22:16 am
SolarSteve
  • 264
Motor Oil
« on: January 15, 2012, 06:22:16 am »
Since the last time I have been on this site Ihave sold my 1991 Jetta and bought a 1997 Passat TDI with the 1Z engine.
I know what oil the owners manual tells me to use and I have heard many different opinions on diferent weights and types of motor oil to use.   I am curently using Rotella 15X40 and changing it every 3000 miles.  I plan to use the Rotella 5W40 synthetic in the colder months.
Can you guys please give me your input on what is considered acceptable oil to use?  I am running it on VO and will continue to change the oil/filter every 3000 miles, so I really don't want to spend twice as much on synthetic oil just to dump it in half or less time.
Thanks in advance for the input.
Steve
91 Jetta 1.6 N/A
Reply #1January 15, 2012, 09:30:02 am
Re: Motor Oil
« Reply #1 on: January 15, 2012, 09:30:02 am »
I think synthetic can be used for quite a bit longer than dino oil.
I currently use 5w40 in my 91 IDI.
Reply #2January 15, 2012, 02:44:21 pm
Re: Motor Oil
« Reply #2 on: January 15, 2012, 02:44:21 pm »
I usually did 5,000 on synth oil changes.
Reply #3January 16, 2012, 07:27:23 am
SolarSteve
  • 264
Re: Motor Oil
« Reply #3 on: January 16, 2012, 07:27:23 am »
I guess I wasn't very clear.  What I want to know is whether or not it ok to run dino oil in my TDI.  And if it HAS to have synthetic, why.
Thanks
Steve
91 Jetta 1.6 N/A
Reply #4January 16, 2012, 08:11:46 am
Re: Motor Oil
« Reply #4 on: January 16, 2012, 08:11:46 am »
I don't know about the first generation TDI, but the ALH and newer had to have the synth with the specific 505.???? or maybe 501.??? I know the BEW had to have the approved oil or the cam would get wiped out. I don't know for sure but I think all of the approved oils were synthetic. I don't know about the 1Z engine, but I would assume that syth oil would be better for it, especially if it calls for it.
Reply #5January 16, 2012, 11:20:00 am
whoabeats
  • 38
Re: Motor Oil
« Reply #5 on: January 16, 2012, 11:20:00 am »
My ahu which would be considered a first gen requires synthetic as well. I would not use dino oil. I have only done two changes of my own on that engine, but I know the previous owner did use only synthetic oil. I myself per recommendation from the local tdi mechanic. Use Rotella T6 in intervals of 8-10k miles. The car has over 210k on it and the engines camshaft looks brand new!!! This pleases me.  ;D
I have a diesel hot-rod addiction
97 2500 cummins 4x4 5 speed 460hp
98 AHU m-tdi being built for a car I dont own
00 ALH TDI handles like a race car, but has no balls
Reply #6January 16, 2012, 11:22:48 am
Re: Motor Oil
« Reply #6 on: January 16, 2012, 11:22:48 am »
i would have no problem running Rotella T 15w40 in any TDI (ALH or older)
my dad runs rotella in his 2006 Duramax, and it has almost 400,000 miles on it, without a single issue to the engine.. still has stock injectors..
Reply #7January 16, 2012, 11:37:48 am
whoabeats
  • 38
Re: Motor Oil
« Reply #7 on: January 16, 2012, 11:37:48 am »
I mean it is ok to use regular rotella or similar oils, but like you have suggested the oil change interval is drastically shortened. The synthetic oil should help in the winter as well. The way I see it is though even if you do 5k mile oil changes that is $12.99 a gallon for Rotella 15w40, but you change it twice as often or more (you suggested 3k mile changes). So it seems it would be more expensive then every 10k miles spending $21.99 a gallon for Rotella T6 5w40. You would be changing and buying filters less often as well. Reason i mention T6 is it seems the most readily available also Delvac 1. These are both found at all auto parts stores and walmarts.
Also about the Dmax that is quite impressive. Luckily it is a newer generation which is why he has had excellent luck with injectors. I hope this means that the newer duramaxs are going to be more capable of high mileage because that is a weak point of a lot of them. Especially compared to Cummins.
Reply #8January 16, 2012, 12:04:57 pm
Re: Motor Oil
« Reply #8 on: January 16, 2012, 12:04:57 pm »
2006 was when they went with the LBZ engine.. the LB7 (earliest) and LLY (02-05?) had injector issues, as well as some other small things..
but the LBZ has a stronger short block, and better injectors, as well as a big garrett VNT turbo..
my dad is an over the road RV hauler, and he puts LOTS of miles on his truck.. i think part of the reason its lasted soo long, is because it gets diesel treatment to every drop of fuel thru it, and it is maintained meticulously.. still sounds the same today, as the day he brought it home.. alot of these d-maxes get louder as they age it seems.. my uncle and cousin both have d-maxes too, with less miles, and the injections have seemed to get louder as they have aged.. they are maintained nowheres near as good as my dads truck tho..
my dad has talked to LOTS of owners of the 2006 and newer d-maxes, and LOTS of them have had ZERO issues with there trucks.
i have not heard of a single actual internal issue with the ALLY trannies.. besides cracking the tailshaft housings..
Reply #9January 16, 2012, 01:12:12 pm
SolarSteve
  • 264
Re: Motor Oil
« Reply #9 on: January 16, 2012, 01:12:12 pm »
Thats all good input.  And like whoabeats touched on, its the price of the synthetic every 3000 miles that is hard to deal with.  I have been considering using the T6 and going 4000 OCI's, but that will still be pretty pricey.  On top of that I am consuming about 1 quart every 3000, so that is adding to the over all expense.  This consumtion seems to be pretty normal, from speaking to other A3/B4 owners and the turbo appears to be in good shape as per my butt dyno.
My manual says to use 505 00.  I have heard of many people with the PD engines using full synth all the time and still wiping out the cam.  I never used snyth in my 1991 IDI and that cam looked awesome at 340,000 miles.  To top it all off, I have a real hard time believing that a VW HAS to use synth when you have all those Cummins and other big diesels that use the dino Rotella for hundreds of thousands of miles without any issues.
So, I guess I am in search of A3/B4 single owner who has used dino oil for the majority of the engines life and see what he has to say.
Any and all other opinions still welcomed.
Thanks
Steve
91 Jetta 1.6 N/A
Reply #10January 16, 2012, 04:22:19 pm
Re: Motor Oil
« Reply #10 on: January 16, 2012, 04:22:19 pm »
The IDI s didn't have cam hardness/wear issues. They did have the flakey look on some of the mexican cams but no failures like the newer stuff.
I know the syth oils have longer intervals. 5,000 is easy. My Shaffer's rep says 7 to 10 thousand on his oil between spinning a new filter on and dumping a quart of new oil in and sending some of the old in for analysis. I wouldn't have a problem doing 6,000 on the T6 rotella personally.
Reply #11January 16, 2012, 05:23:14 pm
Re: Motor Oil
« Reply #11 on: January 16, 2012, 05:23:14 pm »
When i get the M-TDI motor I will be using the 5w50 castrol syntec again, and probably going to do 10-12,000kms on the oil.
Reply #12January 17, 2012, 08:00:25 am
Re: Motor Oil
« Reply #12 on: January 17, 2012, 08:00:25 am »
Thanks
thats what im saying.. my dad has almost 400k on the clock, and his truck has only had synthetic for 2-3 oil changes..
Reply #13January 17, 2012, 08:47:48 am
whoabeats
  • 38
Re: Motor Oil
« Reply #13 on: January 17, 2012, 08:47:48 am »
Its not exactly apples to apples though. I use cummins for example because thats what I know best. But it is a medium duty engine designed differently then a tdi. The life of the injectors on a 12v is designed to be within spec to around 400k miles.  That is far past what I assume a tdi suggest. I believe a duramax uses the same mentality. If my cummins didn't have its typical power steering pump oil leak, I'd probably be running t6 or valvoline premium blue synthetic. For such a small engine such as a vw I can definitely pony up that  little bit extra for synthetic. For a big thirsty engine I'll stick to regular oil. Also before I switched to valvoline I use to use  regular rotella and everytime I got to around 5k miles I would notice a drop in oil level. I switched to valvoline blue and my oil level is steady past 6k.
Reply #14January 17, 2012, 02:31:05 pm
SolarSteve
  • 264
Re: Motor Oil
« Reply #14 on: January 17, 2012, 02:31:05 pm »
I inquired about this topic today with a local VW/TDI mechanic.  He explained to me that the 15W40 dino Rotella is too thick and doesn't handle the heat as well as the synthetic oils.  I mentioned the "if it good for a Cummins, why not a TDI" statement and he told me that the TDI turbo spins at a higher RPM and a higher temp then the Cummins and therefore if I don't use a sythetic oil I will wipe out my turbo.
This mechanic is VO friendly and I also explained that I would be performing shorter OCI's.  He knows that I am running a moderate (RC2) tune with stock injectors and reccommended that I go 4 to 5 K on my OCI's and use T6.
So, I guess I got what I was looking for and changed the oil this afternoon with T6.  Hopefully this will cure the 1 quart per 3000 miles that I have been consuming and my ensures my turbo lives long.
Steve
91 Jetta 1.6 N/A
